R33 Gtr Front Bar On Gts-t + Do-luck Sides & Rear
Hi guys!
I'm new here so thought I'd say a big hello to all of you first!
The guy that sold me my car has a GTR front bar made to fit my GTS-t and I'll be picking it up soon. I don't want to make my car look like a GTR, but i do like the fact that it is more open around the intercooler and gives the car a more aggressive look.
I was wondering what you guys think about gts-t's with gtr fronts and also, do you reckon it will look good with Do-luck side skirts and rear bar?
I'm still undecided as to whether I want to put a kit on my car because the stock look is great - so i was thinking of just changing the front bar purely as a performance enhancement to let more air across the front mount. I've noticed the GTR front also has vents on the side where i can fit piping for a cold-air intake.
What are your thoughts?
Cheers
Chris.
p.s. I've posted a few pics of my car in my gallery, feel free to check them out at http://www.skylinesaustralia.com/forums/LI51CA-m67924.html
Hi mate,
Firstly, welcome to SAU.
Now, there is nothing wrong with putting a GTR kit on a GTS-T as the stock look, in my opinion, doesn't look very aggressive although it's ok.
However, if you got Do Luck side skirts and rear pods...I suggest you spend some cash and get the plain GTR ones as the Do Luck side skirts are a bit fat looking and just wrecks the slick and simple GTR look.
Otherwise, purchase a Do Luck front bar...you can even get one from Ebay for around $350 posted.
I personally like the simple but tough look for the GTR kit all around.
Good luck mate!
Hi mate,
Good luck mate!
Thanks heeps mate
Yeah, i agree. i like the agressive GTR look. However, I'm worried it's going to look weird because the guards aren't as flared as the GTRs. Would you hapen to have any pics of a GTSt with a GTR kit?
Cheers.
Thanks heeps mate
Cheers.
Hey mate,
I wouldn't worry as the GTR-replica for the GTS-T is made specially for it. In other words, it's smaller than the GTR size so it will fit nicely. A lot of people put a GTR front bar on as it looks best on a R33.
Here's a picture of it on a GTS-T.
You can get it from almost any bodykit place. Try www.jetspeed.com.au or www.carmate.com.au for starters!
Good luck!
That does look nice!
I think i made up my mind.
Cheers mate.
Chris.
Hey mate,
No worries...glad you've made up your mind. The GTR front bar, although simple, looks very aggressive and nice. However, one thing to remember - spend $200-$300 on a set of nice GTR front bar indicator lights intact with proper backing not cheap mesh and a round truck-like indicator lights.
You can get them from www.justjap.com or www.jetspeed.com.au - just call and ask for them.
Good luck.
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
