Dyno + Tune
DR1FT4
 Share
basically I've never done/seen it done before so what kinda of cost am i looking at to get it tuned on the dyno?
i would probably get it done at hyperdrive so if anyone has a rough idea thats great cheers
All shops are very different, I know of a car thats been well set up for 7 years,Needed a bit of a tune so he went to a well knowen shop for a tune only to be told his ECU was no good even tho it had been for so long. He was sold a new ECU and the drive away price was over $7000.
The guy drove down the road and ran out of fuel,Got some more and told the tuner the car ran badly and had run out of fuel only to be told his car was not tune as it had no Fuel. 7K drive away with no tune and no fuel is rough and worse still he now finds he has no other tuner options.
Make sure you know what you are getting before you leave your cars anywhere.
I got my car tuned on Friday. It cost me $880 to get a Nistune ecu and tuned. One set fee I've heard. But that was for a rb20det using my ecu. Not sure wat u got.
It was pretty exciting hearing and seeing my car on the dyno. And good results to.
how long's a piece of string? all depends on how well ur car is prepared, best case scenario ur car is functioning perfectly and a tune can only take an hour or 2, but if there are any issues ul have to factor in diagnosis time, parts, time taken to rectify problem etc. my car took half hour on the dyno cos it was well prepared etc, whereas i saw a v6t gemini on the dybno for 2 days cos it was just slapped together
dont get emanage..
emanage = fail
so you have run emange ecu's in your car ????
what didn't u like, a bit more reason than fail might help a few people out, the only reason around seems to be with tuners, not the ecu, most tuners don't know the software, so won't touch
Steve
does anyone know if you can re-tune a tommy kaira ecu?
I have opened it up and it has a chip solderd in there...
If i was to want to up my power would i need this nistune and z32 afm or pfc or can it be done on my tk chip?
 Share
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
    • Yeah, so try to post images with extensions that the internet can handle, not HEIC files which only arstyphones can handle.
    • I have two questions here, The first is regarding the harness attached to the power window and central locking control on the drivers door. I can't understand why the previous owner would join these wires together on the harness and why they did such a shit job. There was a wire with 10v hanging in the open un insulated. The OEM remote control works just fine The second is regarding the blue, green wire attached to what I believe is the lock actuator? These were running to the old immobiliser connected to the 'UNLOCK - COM' and 'LOCK - COM' wires. I imagine COM means communication and they just send a signal to the immobiliser whether the car is locked/unlocked?  IMG_9032.HEIC IMG_9037.HEIC IMG_9038.HEIC IMG_9041.HEIC
    • A name I haven't seen in a while, welcome back. Nothing much has changed, we are all still deluded Nissan owners.
