Track Report: Rota Rims And P-cup Slicks..
  • Replies 226
Posted Images
No they dont, rotas have 5 and rays have six, look up post 64 on this thread.
your correct the rotas in post 64 do have 5 spokes & are the lmgt4 copies, however they're just random broken ones someone pulled off the web a couple posts earlier.
This thread is about LSX-438's set of 6 spoke rotas (the te37 copies) if you read through the whole thread you'll see a loads of photos of his exact wheels, for example in post #1 on his gtr...
yes I am an idiot, thanks for pointing that out.
Dude you're comparing the p45-r which is 5 spoke aka lmgt4 / drifttek copies. the ones duncan have are grid drifts which are 6 spoke and similar to te37 style mate.
edit: just saw your few posts above.
They do look very old. How did they crack? Was it wear and tear/fatigue as in the case of the Rota's or was it a hit? You would need to know that if you are to use that as an argument.
the owner stated no potholes/ditches etc so just appears to be wear & tear.
Got R35 and can not afford set of decent rims? :spank:
please read the thread first........ :)
if i had the money for a 35, i wouldn't be buying rota rims.
but i guess everyone is different.
I just ordered a $7k suspension upgrade today but i am sure it's the wrong set (what would you guys suggest i buy btw?) I've spent about $15k on track tyres in 12 months (several sets of 55's, new slicks, many many sets of 2nd hand slicks as well as new 20" bridgestones and advans recently, all wrong, probably) and $15k again on exhausts, tuning tools, intakes, a few sets of rotors, many more sets of pads, control arm upgrade (all wrong surely). So there's $37k down the drain there. Oh and about $5k on the enkei and rotas too, which we all know about (wrong). So make that $42k thrown away. Oops how about $5k for a stupid active carbon wing (wrong). Make that $47k.
I can't afford the GTR tax on a lot of things. $10k for a set of genuine rotors and pads, how about $2k for some transmission fluid? The GTR tax is.. well, taxing. So we try different things. Some are relatively cheap (and yet better than the more expensive options) and i share the info freely. I don't mind if you think i'm a cheap bastard, no.
Finding this thread pretty interesting as im studying Engineering at the moment (only first year though)
This may just be a load of crap but i feel like researching and giving an opinion.
It says on the Rota site that they use A356.2 aluminum alloy I think this is the weakest of the alloys from what i can gather.
The Rota site also says that they use some form of heat treatment, looking at some standard heat treating methods for A356.2 a method is to heat it too 1000degrees F which is 537degrees C then quenched in water 65-100degrees C.
So you said your brakes heated up to 800 degrees with the rim having about 1mm of clearance from that heat. So my guess would be the crystalline structure in the rim would be getting screwed around every time you took the car out for a track day. Im guessing it would be like welding aluminum how it loses its strength when you weld it.
So the rim becomes weaker due to lack of clearance between the caliper resulting in crap loads of heat making the rim become more brittle and loose strength, and then the sudden temperature drop by driving though water forced it to crack, like using liquid nitrogen on something and hitting it with a hammer..
Well thats my guess as i dont see any flexing on the wheel for it to crack that way.
But hey im only a first year student so i might be wayyyyyyyyyyyyyyyy off, tell me if im wrong... if you actually know what your talking about :wacko:
Just my twoCents :nyaanyaa:
The reason they broke is simple physics. They were stressed to within an inch of their life and then pushed far past it.
Constant heating and cooling cycles on those rims while they're being subjected to hard forces will stress the hell out of them and accelerate metal fatigue. What's the load bearing for each wheel if you don't mind me asking? If you're running a 1700kg+ car and pulling more than 1g in the corners that's going to put a large strain on the wheels too, I'm too lazy to figure out the exact amount of load on each wheel but I'm sure an engineer with too much time on his hands can come up with the answer. And finally the manufacturing process comes into it, a forged wheel is stronger and as such you can use less material when making it to reduce weight yet still have enough strength to put up with the stresses of motorsport use. When a wheel is made to to similar specs using a gravity casting method of manufacturing there's no way it'll be able to take the same amount of force as the forged wheel would.
If the TE37's have the same clearance, i would not be happy to pay $5000 for a set.
:nyaanyaa:
P.S You are not a cheap bastard, just go and get some SSR Type C-RS :wacko:
TwoCents and Intensevil, thankyou for your sensible contribution, even if you're not on the money it gets you thinking.
Edit: i think the load for each of those rims is 630kg, but i would need to check.
Edited by LSX-438
I've been told that 99% of cast wheels use this material; anyone know?
although if we're honest, 99% of cast wheels are cheap junk u pick up from ur local bob jane to make ur laser look speccy!
my original posts have been deleted, but my there point was, you are racing a heavy supercar around a track, you simply cant use what ur average car uses, rotas are just a glorified CSA, monza etc etc which just so happen to come in bigger sizes and offsets, they are targeted at a different market, but they are no different besides that. its one thing to put them on a street car, a low end drift or grip car (although i wouldnt recommend it), but to put them on a track GTR
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
