hey guys im sending a turbo away for repairs so im putting the stock turbo on,
i have a turbosmart manual boost control and i wanted to know how much psi it runs when "Fully closed"
and how much u get for each click "roughly" as i dont have a boost gauge and cant get 1 untill next week
how much psi/clicks should i goto safely with a standard setup?
and should i put the PFC in "standard" and tweak the injectors or should i not do that.
Agreed ^^ - massive backyard fail.
No boost gauge = DO NOT ADJUST.
Every car/setup is different. Play with fire, you will get burned.
Also do not go putting in injectors and hammering away thinking its going to go OK on the stock map.
Have the boost configured when you get the tune - not before. Simple as that.
No way around it, get a boost gauge. Cheap ones from autobarn/supercrap only run around $40-50 anyway, very easy to install yourself too. There's no excuse to not have one I think.
sorry i didnt realise i said i was putting injectors in and then playing with the pfc. :D
all i said was should i tweak the injectors aka "standard injectors" if i run higher boost levels...
so the car doesnt run lean.
but neways ill wait and grab that boost gauge before i change anything.
this is a fail on so many levels
do you even know how a maunal boost controller works ? go and do some research
tell us what mods you have to your car
at the moment i only have my 3" turbo back exhaust and a fmic on the car.
i have so many more parts here but im going on holidays so its a job for later.
Edited by Stealthynsa
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
