89' r32 gtr
engine mods:
2.8 ltr stroke
87mm oversize piston
vspec twin turbo n1s
impul remap ecu
adjustable cam gears
turbosmart boost controller
apexi pod filters
tanabe adjustable coilovers
trust full exhaust system
interior:
impul 300km/h cluster
hks oil temp and boost gauges
nismo centre gauges
4wd to rear switch with front torque control (killler switch)
rims:
buddy club p1 racing rims 16/225
brand new exedy clutch
exedy flywheel (light)
service
brand new tyres
only problem 2 or 3 synchros in the box
but still drive able
PRICE :15K
Call: 0412264311
DO NOT PM ME AS I DO NOT REGULARLY LOG IN CALL!
https://www.sau.com.au/forums/topic/294426-r32-gtr-28l-sale-cheap/
  • 4 weeks later...
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
