in no hurry to sell so low ballers go have a bat, it ll be more productive.
okay up for sale is my s13, can be registered but will need engineers, have upgraded brakes and what not so it wouldnt be hard, ideal car for track, something different too
car was ca18de auto (gay)then converted
RB20DET with RB gearbox conversion done.
Stock intercooler
Alloy radiator with twin thermos so it never heats up
pod filter
exhaust is 3 inch from cat with 5zigen tip, sounds nice and throaty from the mighty rb
has boost controller
car runs perfect only done 90 000 km since its rebuild
gearbox is in very good condition no chirps or noises, shifts well
car is in primer, ready for paint
comes with FULL vertex kit, front bar, rear bar and side skirts looks tough
also it has a r32 gtr wing on it (i thought it was type x wing) slammed it on looks alright
apexi adjustable suspension all round
eibac springs all round work well together
slotted rotors all round.
New pads.
isotta steering wheel.
Drift button.
Black interior.
has s14/r33 front seats, hug well
spit fire boost gauge
apexi turbo timer
kenwood or alpine headunit mp3 and all that jazz with 6X9
rear seats come with car, the rear of the car has been stripped no sound deadening
S14 front seats.
carpet is still there though
any questions jst call i might have missed out on some details
15" DE rims sprayed gloss black will come with the car.
Fronts 90% rear 70%.
price is $5.5k ono with no rego or roady, part it out and make your money fellas or keep it for the track
wheels and js lights come at an extra cost
call 0413 926 794 ALSO WILLING TO SWAP WITH CASH YOUR WAY FOR REGISTERED TURBO WHATEVER CALL ME!
later haters.
https://www.sau.com.au/forums/topic/294459-melb-rb20det-s13-hardcore/
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
