Crazy, crazy story, but that persistance paid off in the end hey?
sure did !
haha!
now tell me, how does one spot bonnet pins at 2am on a freeway...???
=S
Defect station haha, was in the crafers park n ride , i did park but atleaste they didnt ride me :sick:
  • Replies 92
can i just ask whos idea it was to drive 750kms, with 2 dissconected phones and f**k all cash? lol ...
mine because i got fking sick of waiting on people to get back to me about transporting the car over here
mm 26 to 25 thats diffrent in all difrent ways
yeah , i know...
still enough power to skid though
update .
took it out to its first drift practice , went awesomely , except the understeer haha
great thread champ... reminds me of the old saying "bad decisions make good stories!"
yeah thats it , end of the day i love the car and thats all that matters
Goooooood stuff Mitch. :)
Where was that oil leak in my engine? :D
cheers bro , it was on the oil drain hose , got sliced open on the engine mount cover -_-
i will buy the plates !!!!!!!
makea da offa
update//
fixed the front bar up , pics of that soon.
had misfire issues and idle issues.
also gearbox noise from the input shaft bearing.
replaced ECU and filled the box up with 4L of fluid and it runs sweet now
needs more power though
What an epic story. Should sell it to Warner Bros.
yeah bro
pics from drift prac
Sup bro! great story man and sorry to hear about what happend! that was very intresting! im also into drifting as well! i drift my r33 as well, was just wondering whats your suspension setup? I currently have Tien HA coilvers, 2 way diff, rear sway bar, and engine strut brace and rear boot strut brace. Was just wondering if its worth me installing my Pinapples? i got metal ones... from Just jap.. Cheers dude.
yo not much man
if you've got em why not , im yet to try pineappes , might help when i wind the boost up a bit
for now i have no problems getting it into a slide , adjusted my handbrake with a mate so now i lift it one click and the rears are locked
this is what i run:
coilovers
cusco mech 2 way
28mm rear sway bar
rear camber arms
solid subframe bushes
cusco front tension rod
slotted front rotors
GTR rear strut brace
Nismo front strut brace with brake booster
pretty sure thats it bro
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
