  • Replies 114
Posted Images
nick just wonder around outside or around the house and take photos of things, that's what I usually do with a macro lens.. works better with a tripod though
i was about to suggest that. nothing stopping you from using a macro lens for anything
Ahh cool, thanks gents!
I might pull out some of the random collector's edition stuff I've got lying around and take a few shots of those over the weekend. I might go and buy some A3 and bigger sheets of cardboard to use as backdrops.
ohhh ive wanted to do that bridge for a while now! does the bridge get much shake to it? good pics tho :P might go up there tonight :D
you know, I never even considered the possibility of the bridge shacking...
Most the exposures were 30 seconds and not one of the many I took were blury so I guess it's not a problem. Was prety windy though, had to stand between the wind and the tripod to help it stay still
Edited by bnr#@
