ok the motor is an rb25det s1.
my goals are 400hp and retain some form of response or realy not having a very lagy turbo.
the two turbos i have are:
Garrett GT3082r, .63 rear ext gate
HKS TO4S, .7# rear or and option to use a larger .8# rear ext gate.
now i know the Garrett is ball bearing with the smaller rear but i have read they suffer compressor surge??? and the HKS is old design and not ball bearing so i can expect it to not be as responsive as the Garrett.
i drift ALOT so i want a turbo that is going to be usefull to me.
What would you choose of the two.
Thanks, Steve.
https://www.sau.com.au/forums/topic/294491-what-would-you-choose/
Agreed.
400hp is what, 240rwkw-250rwkw give/take.
GT3082 - too big, will produce another 50rwkw in a sniff
HKS T04S - too old/laggy, same as 3082, more power
GT3076 - NOW you are talking a turbo fit for a task.
For more details on the 3076 - a simple search is all that's required.
discopotato & plenty of other users have posted more info than you'll understand :(
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
