hey guys,
going to go to a dyno within two weeks but just keen on wondering what your opions of power output i may or may not make on a dyno with these following mods
Rb20
rb25 s2 turbo (10psi)
FMIC
POD
Z32 AFM
Nismo 555c injectors
Yellow jacket coil packs
Greddy E-Manage
NOS 50-150 hp kit
(Maybe Cam Gears)
https://www.sau.com.au/forums/topic/294516-rb20-power-output/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
