hi,
been looking around but couldnt find anywhere as to whether it is posible to remove the hideous looking and cluttery factory oil cooler,
the thing that sits on the block before the oil filter... would look so much nicer with it gone plus be ALOT easier to get in and around the engine there..
i do have a proper oil cooler so just dont feel this thing is necessary..
advice much appreciated,
thanks
surely some company out there must of made a plate that replaces the whole factory item with just an oil filter mount or better still braided line fittings as most people would run a remote oil filter..
Actually, you just unbolt it, and screw your oil filter on to the block...
Yes, I'm deadly serious.
What, unbolt & remove plate which cooler & filter are attached to & then screw filter directly onto block? I take it thats not what you mean?
No its not the way to go if thats what is meant. Block has no thread to screw an oil filter onto. Stock plate (which filter & cooler are attached to) just slides on, with an o-ring to seal & bolts to secure it
Have had factory oil-cooler & plate off but they ended up going back on. Thinking maybe non-turbo model has a plate between block & filter without provision for cooler or possibly cooler can be removed with a bolt blocking passage to it... Not 100% though. All I know is you cant remove that factory plate & just screw filter directly onto block
thats what i was thinkin.. so back to other idea has anyone ever made a plate to bolt back onto it with just a pair of earls fitings or the like so you can just run braided lines off it to the remote oil filter and cooler..
im not after the cooler or remote filter locator.. just a plain old bit of metal plate to replace the factory coolant operated oil cooler as i want to rid my engine bay of all excess CRAP in it to simplify things up a bit.. PLEASE ONLY post if you have had experience with this or no about it, sydneykid have you had any experiance with this??
Edited by R33_KRAZY
Well on 4 of my blocks (2 x RB25, 2x RB30) it was a matter of on the 25s, just completely unbolt the heat exchanger off the block, and screw the oil filter direct onto the block.
When I head down to my mums house next I'll try get some photos of the RB25 block that's down there stripped. It screws straight on for me, on 4 blocks.
From memory it's 4 12mm bolts that hold the oil cooler on, take it off, and my oil filter screwed straight to the block.
On my 25 there was only an unthreaded locator for the heat exchanger coming out of the block. I ended up using an RB20 oil filter mount and connecting the coolant hoses to each other to bypass the cooler. If you could get a threaded insert from an RB30 block you could fit this in the unthreaded locators place and have the oil filter straight off the block. I end up going with the RB20 mount though as I already had a remote filter and cooler and it looked like the hoses to the remote filter would foul on the engine mount if it was in that close to the block.
I also had to make up two longer fittings for the remote filter mount as the RB20 mount has the oil filter sitting directly over its center whereas the RB25 heat exchanger has the filter offset 30mm? or so towards the front of the car. Not much of a difference but enough that the hoses to the remote mount could no longer reach.
Clears up a bit of space under there :P
Edited by Mister25t
thanks heaps mate sounds like the way to go.. ive got the head of the engine at the moment and really wanted that hideous thing gone when i seen it ;) im trying to hide and remove as much stuff as i can.. BTW anyone got an rb20 filtor mount for sale :P
Edited by R33_KRAZY
thanks heaps mate sounds like the way to go.. ive got the head of the engine at the moment and really wanted that hideous thing gone when i seen it :) im trying to hide and remove as much stuff as i can.. BTW anyone got an rb20 filtor mount for sale :D
Yeah it was one of the first things I done to the car. Rates ups there with HICAS ;)
Also if you go that way with the RB20 mount it doesn't have provision for the oil pressure sender. Fortunately there is a tapped thread for it already on the block right below where it is positioned on the heat exchanger. I had to get a fitting from an engineering shop because the diameter of the oil pressure sender is too big and it was fouling on the webbing running down the block. It needed to come out just slightly to clear it (my oil pressure sender is a bit bent though. Somehow :) ).
No biggie, just get a brass male and female adaptor 1/8"x1/8" bspt I think was the size. Then you can remove the plug in the block, fit the adaptor then screw your oil pressure sender into that and you're away.
    • It can't be some stupidly proprietary video signal coming out of it that only Nissan's can understand. Surely you can just find some generic camera to stuff in there and use hot melt glue/blu-tac/gaffer tape to hold it in place if need be?
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
