  • Replies 72
http://www.trailbiketours.com.au/hire.htm
that seems pretty cool! $200 to hire their bike for the day..
hmmmm :)
That looks like it would be heaps fun.
Interested
moar texis and driver training type of track days (like the one coming up on the 18th at OP)... oh and taxi service for those without a licence would be awesome. You get to drive someone elses' skyline for free and they get to get out of their home win-win :)
I haven't been to a texi/skidpand/track yet... as someone said not everyone can afford to trash their car/daily due to risk of ruining tyres and whatnot but for me it's a nonissue at the moment as the car's sitting in storage anyway so bring it on!
+1 for fishing type of trips .. Windsor has a nice park right accross the bridge with plenty of parking and mullet and carp are easy and fun to catch, plus the whole area is ideal for bbq/pincin/kicking a ball around ( http://maps.google.com.au/maps?f=q&sou...mp;t=h&z=18 )
That windsor place looks good.
drag day :)
sounds good to me.
What about a dent removal day?
Seen it work with other clubs with great success.
find a dent removal guy
find a workshop who can host a heap of cars
maybe tie it in with a dyno day
get all the annoying little dents fixed at a much discounted price
Sounds even better.
I know SAUNSW is made up largely of Sydneysiders and such but could I suggest something like doing the Harbour Bridge climb or something that is more for the social side? I mean we do a lot of car stuff and yes we do have a lot of strong friendships among the clan which is why I think we should do this as a social event to get more of the new members to fit in with the core clan. :)
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
