Hi,
I am selling my Nissan skyline R33 after i have been just pulled up and fined for having no P'plates displayed, i was handed a three point ticet, and i have no points as i am on the option sheet. So i will lose my license for 6mths. This car is in extremly good condition, totally original, never boosted, never modified, not even an exhaust system or pod filter. It has just been fully serviced with history papers from here and japan. It also has balance of warrenty still available, it has one year left. Here are the detailes of the car.
Nissan Skyline R33
Series 2
Turbo
5 Spd Manual
66,190km (with service history from new)
White
Full GTR kit
17" wheel, the look good, but i don't know what brand they are. They are 17"/8.5 on the front and deep dish 17"/9 on the rears
I have just spent $1800 on tyres, 235/40R17 Goodyear Eagle F1's on the front(the brand new ones) and 255/40R17 Dunlop LM702 tyres on the rear. The reason i didn't keep the same tyres on front and back is because the F1's don't come in 255. All yres are brand new.
Blitz Turbo Timer(also shows how much boost u are running but cannot alter it)
Has a Turbo muffler but not a aftermarket exhaust system.
This car is totally original, no scratches or dents, and has been very well looked after.
Asking 22,500 ono
If anyone is seriously interested post me here or pm me for further detailes.
Cheers, Mark
Here is a picture of the car.
https://www.sau.com.au/forums/topic/29457-fs-white-r33-series-2-gts-t-manual/
  • 3 weeks later...
I am in melbourne, and i can get other pictures, what angles are u after?
Is it a 95 or 96 series 2 ?
Would you mind sending some pics to clkhoo@bigpont.net.au ? thanks - any angles would be fine mate... prob one from front, rear sides, rims, intereior and engine bay.
ps: Im in sydney, are u firm or negotiable on the price ?
  • 3 weeks later...
Its got Series 2 headlights series 2 grill and bonnet, but an aftermarket front bar. 400r or gtr copy, it appears to be a series 2 just check the interior, series 2 interior has passenger side airbag and the cloth of the seats are different. my 2 cents worth
    • As GTS mentioned, it takes a bit of faffing, some fiddling and a little modifying.  With the strainers, you can buy different styles. Some sit flat on the pump, some angle down.  Here are some photos of mine, ignore the ugly welds lol.
    • The smart thing is to actually locate the pump at the right point down the hanger, so that the strainer can stay sticking out at a right angle, but near the bottom. This is the perpetual hassle with retrofitting any different pump to the factory hanger. Some just go where you need it to, some need fiddling and faffing, and modifying of stuff.
    • Some updates. After a lot of praying and some inspecting of crank threads, we've found that they were both kinda munted but nothing seemed terminal. The other option was drilling and helicoiling the crank. That is obviously the last option so we decided to at least try to get a OEM GM bolt in to GM Specs. So after honing/linishing the balancer from it's .002" interference fit to a .0018" to .0015" to .0013" it eventually slotted on to the crank. ATI state the interference is nominally 0.0007-0.0009... so it's still snugger than ATI reckon and explains the issues we had to fit the thing to begin with. New GM bolt went in at 37 ft/lb then torqued 140 degrees after which was EXTREMELY   but it tightened up to 140 degrees and it was a lot of force. So all things considered, the balancer is secured to the exact specs that GM want with the OEM Stretch bolt, (that ATI say you can use..) and the balancer itself is seated and snug AF. So WOO. Engine is now back in the car with lots of swearing. Bellhousing bolts done up, driver side manifold is on, AC Compressor and hard lines are back on the car. Next step will be to connect various engine bits/wiring/intake/radiator etc. Then oil and coolant and ... test start it? And of course, looking into this issue... which actually doesn't look so bad - It looks like it can be twisted back into shape with a set of multigrips. Anyone wanna buy my bonnet? Boy it looks good over there and sunk cost sucks.
    • Also this may be a stupid question, but how would you recommend getting the strainer on a downwards angle ? as they tend to obviously clip to the bottom of the pump which usually sits level 馃ゴ
