1997 R33 Series 2 120,000kms
I have owned the car for a little over a year, before that it was owned by a friend for a about a year.
Serviced Every 5000km or less with Motul turbo light 10w 40w
Motul Diff Oil
Redline Gearbox Oil
Modifications,
Apexi Power FC Tuned at 12psi (made 201kw)
Blitz Dual SBC boost controller
Split Fire Coil Packs
Walboro Fuel pump
Blitz turbo timer
R34 Turbo (OP6)
RB20 Wastegate Actuator (10 psi)
Split Dump/front Pipe
3in Hi Flow cat (inside not bashed out)
3.5 inch HKS Hi Power Exhaust
Apexi Power intake filter on custom made Metal intake pipe onto the turbo
(Pod not totally boxed in but covered over see photos below)
Standard RRB20 Blow off valve
Greddy Front Mount Inter cooler and piping
Alloy Radiator
Heavy Duty Excedy Clutch
Braided Clutch Line
Braided Brake Lines (ADR approved)
Master cylinder stopper
Front and Rear Strut Braces
Bilstein Shocks and King Springs
Front Whiteline adjustable Castor Bushes (adjustable on car)
Rear Whiteline Camber Bushes
Work Emotions CR KAI 18 x 8.5 in all round
235/35/18 federal 595 SS on the front (70%)
235/35/18 Sumitomo HTR Z 3 on the rear (70%)
Work Wheel Nuts
M Spec side skirts and rear pods
33 GTR rear seat
Have had the Roof lining, A-Pillar and B/C Pillar trims redone in Black Suede (haven't done the sun visors yet)
Only need front GTR seats and interior done
White LEDs' in the cluster
Have Changed the AC Panel, cigarette lighter surround and ignition barrel surround lights all to blue LEDs'
Pioneer Head Deck (DEH-P6850MP)
Pioneer Front Speakers and tweeter
Pioneer Rear 6in Speakers
And finally the rear "Skyline" Boot garnish lights up red with taillights :(
There is probably more little bits and pieces i have forgotten but i think that will do, Basically the car has never missed a beat in the last 2 years runs great drives beautifully and handles well. Overall i think its one of the nicest R33's running around. Has been my pride and joy for a little over a year but its time for me to move on, Pictures Below feel free to ask any questions.
Price - $18,990 Will get RWC upon Sale
Plates Not Included
PM for my contact details if you are interested
and have a few more photos too
Cheers Scott
Edited by 13thracer
https://www.sau.com.au/forums/topic/294572-1997-r33-series-2/
  • 2 months later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
