Would Someone Like To Lend Me Some Car Stands?
Hi all,
I want to change the springs in my R32 GTR, it currently has koni shocks with king springs front and hks springs rear.
I want to do it as cheaply as possible by taking the shocks and springs out of the car and hand them to fulcrum to check out and change the springs over.
In order for me to do it, I need to leave the car jacked up on some stands for a week.
So, Would someone like to 'lend' me some Car Stands for a week?
I'm in Norman Park and am happy to pickup and return......
hope it doesn't hurt to ask.....
Thanks,
Fraser.
What a champion, thank you! btw: norman park is across the river from New Farm.
will PM u.
Fraser.
flame flame flame. just joking. Got 2 sets if you need, from sunnybank. (don't know where norman park is)
    • C34 Stagea RS4S Standard RB25DET Neo with ARP Headstuds and MLSR Gasket. Bosch 1000cc injectors Walbro 460 Standard neo inlet plenum w/rb25 s2 throttle body 6 Boost Low Mount Manifold Turbosmart Gen V 45mm wastegate (recirculated) Pulsar g30-770 (0.72 rear housing) 3.5"intake pipe to clear mounts, 3.5" dump to 3" exhaust Link G4X Ecu 380 hp on 98 octane, 478 HP on e85 (mainline hub dyno) Video of Earlier Run VID_300701109_043404_458.mp4 Final Dyno Sheet:
    • Meh. Every single gear in my gearbox will crunch. I've been treating it nicely for >12 years now.
    • How fast are you doing the downshift? 4th gear was revised multiple times until 1998 to fix this issue. Synchro clips can fall out, synchros can wear. Most likely you're looking at a new transmission unfortunately. If you need to limp it until then double clutch downshifts into 4th.
    • Sorry I was being harsh there, but am I wrong? You can buy a M340i easily, and there's loads available second hand. A lot more workshops modifying them as well. How about getting parts for them? Don't get me wrong, I'd love a 400R, even a 4cyl (I looked at a few V36s before buying my shitbox BMW). Sadly Infiniti died in Aus and we're stuck with importing them as niche vehicles. Supply and demand
    • Probably straight swap for an R32 GT-R? lol
