Hi guys,
Would anyone happen to know whether a first gen PFC hand controller (415-N001) would work with an 'ECR33' denoted power FC?
I know the above hand controller will work with an 'RB25' power FC, and an 415-X001 will definitely work with the ECR33 model PFC.
But yes, I need to know ASAP whether the older model hand controller will work with the newer model power FC.
Please don't speculate, I really need an answer from someone who knows.
Thanks!
https://www.sau.com.au/forums/topic/294589-ecr33-power-fc/
Yeah the PFC FAQ Guide is actually what is prompting me to ask.
It mentions that new hand controllers won't work with older PFCs, but doesn't go into whether old model hand controllers work with new PFCs...
Also thanks for the reply Tets!
https://www.sau.com.au/forums/topic/294589-ecr33-power-fc/#findComment-4918235
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
