The guy that tuned my car (an old-school Datsun rally driver) convinced me that my car was a menace to drive on account of it being too low in the back and having terrible bump-steer every time the rear end bottomed out.
He told me that he had some "suitable" springs, and supplied and fit them for next to nothing.
I concede that the car does handle much better now... but the height in the rear is back up to standard, and the car looks kind of odd with it's butt sticking up in the air (although apparently the view of my spinning tailshaft when you drive behind me is kind of cool).
Previously the car was on Pedders red "low" springs - so they are out.
My old rally wreck was on yellow King springs which I sold off cheap before I ever tried driving on due to their diabolical reputation, although they did look to be somewhere between high and far too low in terms of ride height. Also I have heard that cutting a springs to lower the ride height is a really stupid idea because it affects the handling of the car (but I won't even pretend that I understand the physics of why that is).
There are springs available from other Datsuns e.g. 240K that will physically fit my car - but the K is slightly lighter than the C210... is this a big issue?
Anyone got any ideas or recommendations?
It's nice to be finally making improvements to my car rather than just repairing the broken bits for once!
https://www.sau.com.au/forums/topic/294599-c210-ride-height/
The main problem in lowering a Datsun/Nissan with the A-arm rear suspension is that you start to toe-out the rear end. Lowering lowers the centre of gravity of the car (good thing, generally), but also affects the roll centre (probably a good thing).
The K springs are probably a softer spring, which is probably advantageous to get the arse to squat under acceleration. From experience, super heavy rear springs prevent the rear end putting power to the ground, especially in the wet.
Cutting springs is not a problem, as long as the spring can remain captive at full droop. It gives a "stronger" spring as well.
Agreed; the adapter set up sounds unreal... did you buy it or make it?
I read some of the other posts re: s13 conversions, but missed some fairly vital info. Do I need to purchase the S13 coilover spring and shock as an assembly, or will the S13 spring fit over my existing C210 shock? Also is there a spring... tension/weight/setting??? (someone suggested 6kg for the rear) that I need to ask for?
Gordie, if your car is handling well, I'll try and copy what you have done to the letter.
Good to see things are going well with the Datto for you man,
The coilovers should come as a complete set, with the spring on an adjustable perch. Most should come with adjustable shocks too I would think?.
6kg springs should be ok, don't go much harder if you like your spine the way it is.
If you can get some spec's up for those adaptors I might be able to knock some up at work, measurements would have to be spot on tho. Thinking about doing the same with mine.
i bought the adaptors off a guy who had them in his hr31.
but any machine place you be able to knock some up easy as.
just went and took some pics of what i'll be using.
There are the adaptors
c210 v's s13 coilovers.
and the adaptors on the s13 coilovers
this is the ride hight with the stock springs
(this is when i first got the white car a few years ago)
c210 has 3 bolts on top at the rear. s13 coilovers have 2. so you'll have to drill a hole up top to fit it. that old yellow parts car i sold to nick had this done.
you could just swap the top hats off the suspension?
just undo the 1-2 nuts in the middle and your good. and if you've removed stock springs from a shock before you would know u need spring compressors so the springs dont knock u out.
Edited by Dan_J
yep, you can do it that way, but if you have some good quality coilovers you will lose the pillowball bearing set up, and possable the damper control knob.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
