Actually my bad Mercury is the most dense at 13500g/L.
Also isn't Mercury (Hg) the only metal who is in liquid form at room temperature?
(I think I remembered something :P)
Yeah, becomes a solid at like -40 degrees or thereabouts. Not 100% sure if it is the only metal thats a solid at room temp, but it's the only one i can think of.
Here's something that i thought of that a lot of people might not have seen while on the topic, i got shown it at uni. Its's a non-newtonian fluid that has different values of viscosity depending on what type of load is appled to it (shear stress and shear strain). In lamans terms it appears to be a liquid however when hit with a force on an area behaves as a solid. Watch :P
Once u've watched that and understand how it works watch this one, pretty freaky.
Edited by PM-R33
Well I thought this guy would get a bunch of smart ass answers but I just learnt alot more about the scientific properties of water :cool:
Dont worry i didnt forget about ya....
Its half as heavy as 2 litres of oil...and twice as heavy as half a litre :)
Here's something that i thought of that a lot of people might not have seen while on the topic, i got shown it at uni. Its's a non-newtonian fluid that has different values of viscosity depending on what type of load is appled to it (shear stress and shear strain). In lamans terms it appears to be a liquid however when hit with a force on an area behaves as a solid. Watch :cool:
That's some awesome shit! Wasn't there something about body armour being made from a liquid that acts like a solid as soon as a bullet hits it?
You could also make the bullets from it I guess...would turn back to liquid after penetrating the body hehe.
Water has a density of 998g/L. ....
wtf? this has been bugging me for 2 weeks. wasn't the metric system based on the properties of water, and in this case that 1kg = 1lt? do you mean sea water, tap water or some other wierd water? or actual pure water and they just f**ked up?
Ok this is a little bit tricky, i dont remember all the information regarding the original density defined by the metric system and why it was classed as such, but this is what i remember.
Since water is such a special substance with it not following the same rules as other liquids it's density changes so much due to temperature. I beleive water never actually reaches 1000g/L. At room temparture (around 20-25 degrees) water's density is close to 998g/L. This is what is always used in physics calculations and what i have always used throughout uni. At around 4 degrees water is closest to 1000g/L at 999.9g/L, however since it is rare to have water at 4 degrees for certain calculations, it is always classed at room temperature. Obviously for calculations that don't need to be exact, people use 1000g/L. I beleive nowadays with the metric system water is classed as 1000g/L @ 4degrees celsius.
Like i said there is a lot to water since it is so special and im sure there are a lot of other people that know more about this than me.
The metric system is very interesting with how every single unit of measurement is based on something. The one that i find the most strange is the gram. It's the measurement of 1/1000 of a specific object which is kept in a sealed vault in France lol. I beleive it is the one of the only ones that isn't currently related to maths or the earth, however they are trying to change that so it is (like 1m was originally defined as 1/10mil of the distance between the north pole and the equator through Paris haha. They later changed that though).
Edited by PM-R33
I thought that water hit 1000g/L at 4°C, at an unknown pressure.
When I was still doing high school chemistry, all published attributes for any chemical reaction are taken at "Standard Temperature and Pressure", which back then was 25°C and 1 atmosphere.
Oh no doubt at a different pressure you could probably make water be 1000g/L. However at 1 atmosphere im pretty positive it doesn't reach it. Falls short at 999.97g/L or something. Come on, where are the chemical engineers on this forum to help us out :P
Edited by PM-R33
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
