Hi Guys,
Ok so I did a search and noticed alot of threads on knock as you would expect, but my question is slightly different to the others.
My car when on limiter will flash the check engine light. Now before you say "well dont bash limiter like a dick", I'm talking first gear, coming on hard and lighting up the rears straight away, the car races to limiter and still has alot of first gear left to wind out.
The car NEVER knocks when just under load (I say this because the check engine light doesnt flash, however I do not have a hand controller with my PFC to get a figure)
I am assuming the sensor is picking up multiple other noises that occur when on limiter, as everyone knows the noises when bashing limiter are plenty.
Car is a S2 R33 GTS-t making 350rwhp on a HKS GT-RS. 15-16psi
A/F's on the dyno were 10.5ish and the car is tuned my Marc Jacobsen of Godzilla Motorsport.
I guess my question is does anyone else has a "safe as houses tune" that shows signs of knock on limiter. I'm planning to take it to the strip over the next two weeks and want to make sure that all will be fine. Obviously launching it its going to bounce limiter abit...
So from personal experience, has anyone else with a nice "safe" tune show signs of knock when on limiter?
Edited by Granthem
https://www.sau.com.au/forums/topic/294617-knock-on-limiter/
I get very high knock at the top of third on very cold nights... Unlike you, I'm CERTAIN it's knock cause it reads Knk: 140 !!! ;)
There are 3 reasons your engine light will flash:
1. Knock above 60 (I think it was 60)
2. Maxing out the injectors
3. Maxing out the AFM
Most tuners will turn 2 and 3 off if they are sure that they won't be causing a problem for you. What injectors and what AFM are you running?
Also, you should really invest in a hand controller, they can show you an amazing amount of information!
I know I know... a hand controller is on the cards!
As for AFM - Z32
Injectors - Nismo 550's
Thats the problem, I dont really know the "figure" its knocking too, however I'm assuming if its not showing the knock warnings under load during the revs, I'm thinking the sensor is picking up another noise when on limiter, as least thats what I'm hoping ;)
The chances of that happening are very very rare. I wouldn't bank on that.
Your AFM and injectors should be fine, so I dare say that it's knock. Most of the time knock will happen at or near the limiter, not just on load.
Sounds to me like a simple case of knock. Was the car tuned in winter? The ambient air temp is raising dramatically at the moment, so any 'super safe tune' done in winter would find itself out of the water in summer.
i have my check engine light set at 40 knock and i have never seen it come on, even when abusing the limiter drifting.
i'd be getting it checked if it was mine
Hmmmmm interesting. Thanks for that. OK no limiter bashing for me! Time to tip toe around ;)
knocking when the engine is smashing the rev limiter is completly normal. every car is different - knock sensors are in different condition and engine makes different noises to other engines.
with my car it would knock badly on the rev limiter when i had the power fc. other engines don't.
i would not worry about it. That goes for you too Dr Doof. if its knock when your hitting the limiter then forget it
if it knocks before the rev limiter cuts in then you should worry. think about it.. all hell is happening in the cyl's when the rev limiter is working... what do you expect it to do? sing a lilaby ?
and also the engines are more prone to knock when its at MBT. so with your turbo that would be around 3500rpm. Call Marc and he will explain it to you
Lol this is what I was thinking. I mean there are a number of bangs, explosions and noises when bouncing limiter. I assumed if the car was truely knocking it would be showing signs of it during the rev range like you have said. I am of the believe it is registering another noise, and not true knock.
And it does sing a lullaby... a nice RB limiter lullaby ;)
hahhahaa! your tune is fine. they don't call him Godzilla for nothing :)
I used to let go of the throttle a little when its about to hit limiter, wheels are spinning anyway so its only going to make the limiter bash a little less savage and after you practice this for a while you will get better and better and the engine light will stop flashing all together.
hahhahaa! your tune is fine. they don't call him Godzilla for nothing ;)
Yeh you are correct I'll have to practice my throttle control to minimise it. I have never owned a car with a lightened flywheel before, and I must say I've noticed a difference. The thing revs crazy quick.
Jeez, your tuned for 10.5:1 AFR's at WOT??
Thats what it ran on the dyno up here yup. They said there is plenty of power hiding in it.
Lets just say there is enough fuel to create "small" (very large ;)) flame shows...
Well....when i got mine tuned at matty's, he said not to worry about the limiter, its normal.
BUT, your problem has only happened to me a couple of times. So i changed the spark plugs (1 was shattered) and it didnt do it anymore. Even banging on limiter i dont get the check engine light, unless I have the pedal to the floor, still banging on the limiter.
Maybe put in a new set of spark plugs, and try again?
if your really worried about it you can take a degree or 2 of timing out around limiter (borrow someones hand controller if you dont have one). limiter is hardly a place where you need more power anyway. but as said every cars different, i get some pretty crazy knock readings on limiter, she be right
borrow a hand controller and you will be instantly be able to see what's happening. it could be your injectors hitting 100% duty at that point, or the AFM peaking at 5.115v or it could be knock. borrow or buy a HC and you will KNOW what it is and even better you can do something about it if need be.
Yeh i have a WTB add posted up, hopefully someone has one i can snap up.
Injectors are 550's and therefore shouldnt be near 100% i wouldnt think... same goes for the Z32 AFM.
But i will definitely do my best to source a handcontroller and see whats going on :laugh:
i just had my 33 tuned last week, no knock above 30 until tonight..... i decided to put my foot down in 2nd (didnt reach the limiter) the knock was going ape sh!t and hit 98 so i did the same again to see if it was a 1 off, but it went to 60. i was stressing out a bit so i left it sitting for a while. just came back from a drive putting my foot in 2nd through 3rd and it only went to 30..... im hoping it was just the warm weather causing it to rise.....
I think your motor knocks bcause of rev-limit lean out. the Power FC (like stock ECU) cuts fuel as a rev limiter, opposite to the desired way to cut spark to stop combustion. this is the way I understand it ( drunk blurb ), You can get knock couple of ways, and possibly others but lean fuel mix and hot combustion would do it. knock on the limiter is bad but it's not as bad as knock under load cos it's duration is longer.
stay off the limiter or diy and upgrade fuelpump and fix the voltage on the fuelpump wiring. making the fuel richer all round might make the car feel sluggish tho.
Octine booster off the shelf didn't seem to work until I put some NF race octine booster (6 ron). It reduced the knock level on PFC, from 74 to high 20's. and even after hitting the limiter at 7700. handset is good for recalling all readings too.
Im curious to find out the limit of stock RB series motors. I think it's related to hitting the limiter and leaning out. I thought the upper limit was at 100 on the screen, but someone on early reply got 140! The motor makes most power at... it's best cam timing and leanest fuel ratio. it's probly case by case and a matter of opinion how much before motors usually pop and associated knock reading.
I like knowing the RB20 handles being on the limiter better than other RBs when running with PFC.
when my car knocked at level 74, stock internal 20 with 84c water temp no oil cooler and 300whp at 20psi boost. so smaller knock reading on the limiter might be ok as long as it's resonable rev for the motor.
thats my 2cents
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
