my knock went up to 74 today , howcome though ? this is wierd... like when i put my foot down (wheels spinning) then at about 4.5rpm i changed into 2nd gear... the knock is 74 . Why does this happen?
you get knock from more load on the motor on the same management settings, second gear is more load.
but there's many other reasons. Im not an expert tho
if you guys are noticing more knock then try and remember the type of fuel you put in your car last.
I always found that Caltex made my car knock like crazy and optimax / v-power was not much better but it was better. When i switched back to BP Ultimate 98 or Mobil Synergy 8000 it would go back to normal.
give this a try
yep i only use bp nowdays, after going through a few bad batches of caltex. if you had your car tuned and its knocking (not on limiter), take it back and get them to fix it, you payed for a tune, if its still knocking then they havent finished it yet.
fuel cut limiter does not create a lean and dangerous combustion, theres no combustion at all, due to there being no fuel. the ecu does not fire the injector at all when its cutting that cylinder. even if a little fuel made its way in there from a previous injection it would not be anywhere near enough to ignite. if the motor is actually knocking on limiter its from a cylinder thats firing normally, not one thats being cut. like i said before, if your worried about knock readings on limiter, take some timing out temporarily and see what happens.
  • 4 weeks later...
depends how lazy your tuner is, some tuners only bother to tune cells that are traced on the dyno, so when you're on the road those other cells are loaded and POW BAM.. knock...
I had to borrow a Datalogit and fix up my tune on my own after, and at 7200rpm, I pulled out 2degrees of timing, so on Load points 16 and 17, it's 13 and 12 respectively.. and I've set my rev limiter at 7300rpm.. at 6800 it's 15 degrees then at 7200rpm it's 13
rev bashing in 2nd I usually don't get knock more than 50.
BTW.. you can get Innovate LC-01 Kits with Blue Gauges on eBay for $250 delivered.. love the strong aussie dollar!
if you have your limiter set slightly higher than a ne point you can interpolation to only lower your timing on limiter. on a 25 7200 is ne18, if your limiters at 7300 then you can simply take a lot of timing out of ne19 and your timing wont drop until 7201rpm. wont make much difference but it'll make sure theres no knock on limiter without sacrificing power in the last 400rpm before it.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
