hi people as tittle states i am looking at selling my engine set up due to wanting to go turbo v8 now.... the motor has only just done 120km and is still running in.... make me an offer if you are a geniune buyer please..... owes me over $30,000. dont be affraid to make an offer only if you have the money.
ALL OFFERS CONSIDERED
(rb25/30)
prept rb30 block
nitrided crank
dowls removed from crank
acl race bearings mains, big ends
crank collar with grub screw
n1 oil pump
new water pump
spool h-beams rods
arp 2000 rod bolts
wiesco custom 25/30 pistons 7.8-1
total seal gapless rings
cometic head gasket
rb25 head convertion
performance valve springs 65 pound
adjustable cam gears
keford billet cams 272deg 9mm lift (intake/exhaust) non vct
porting and pollishing intake and exhaust (12 hours)
1mm over sized stainless intake/ exhaust valves
arp head bolts
strut brace
ROSS RACING harmonic balancer
cometic inlet gasket
cometic exhaust gasket
gcg exhaust manifold t3 flanged
tial 38mm waste gate
screamer pipe
garrett t04z with t3 flange rear housing for faster spool
custom front mount and piping
tial blow off valve
3" exhaust
custom MR ENFORCER plenum with trumpets
xf throttle body
haltech e11v2
eboost 2
individual coil packs
billet fuel rail twin -6 entries with a -8 return
seimen 870cc injectors
turbosmart fpr2000 fuel regulator with gauge
competition black 100gph carter pump
2x044 700hp pumps
twin outlet 4ltr surge tank
braided fuel lines
nos fogger system 75hp shot
turbo bag
pwr alloy radiator
1000cfm thermo fan
jim berry custom clutch 4400pounds 4 puk solid center
r33 gear box
oil filter relocation kit
+ heaps more
bigger turbo setup:
6 boost manifold
billet t72q turbo
heat shield
progate 45mm waste gate
4" inlet with pod
4" dump pipe
the car made 488rwhp with standard head and ran 10.82sec 1/4, with 1.51sec 60ft, car lost traction at last quarter of track due to line coming off and sprayed oil on tyres and still did the time......
new engine ant turbo setup will make close to 600rwhp on pump, and over 700rwhp on c16 with more boost..... no money spared on the motor.....
kirk 0410757949
P1000363.jpg;)
Edited by grunter01
https://www.sau.com.au/forums/topic/294626-big-hp-rb2530/
yeah it was, and still is at the moment
may consider parting the setup if i get people wanting most of the parts.....
Mate I saw what you are asking for on CT.
Its a f%cking bargain. I am surprised it hasnt been snatched up already.
GL with sale anyway mate.
https://www.sau.com.au/forums/topic/294626-big-hp-rb2530/#findComment-4920198
  • 3 months later...
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
