hi people as tittle states i am looking at selling my engine set up due to wanting to go turbo v8 now.... the motor has only just done 120km and is still running in.... make me an offer if you are a geniune buyer please..... owes me over $30,000. dont be affraid to make an offer only if you have the money.
ALL OFFERS CONSIDERED
(rb25/30)
prept rb30 block
nitrided crank
dowls removed from crank
acl race bearings mains, big ends
crank collar with grub screw
n1 oil pump
new water pump
spool h-beams rods
arp 2000 rod bolts
wiesco custom 25/30 pistons 7.8-1
total seal gapless rings
cometic head gasket
rb25 head convertion
performance valve springs 65 pound
adjustable cam gears
keford billet cams 272deg 9mm lift (intake/exhaust) non vct
porting and pollishing intake and exhaust (12 hours)
1mm over sized stainless intake/ exhaust valves
arp head bolts
strut brace
ROSS RACING harmonic balancer
cometic inlet gasket
cometic exhaust gasket
gcg exhaust manifold t3 flanged
tial 38mm waste gate
screamer pipe
garrett t04z with t3 flange rear housing for faster spool
custom front mount and piping
tial blow off valve
3" exhaust
custom MR ENFORCER plenum with trumpets
xf throttle body
haltech e11v2
eboost 2
individual coil packs
billet fuel rail twin -6 entries with a -8 return
seimen 870cc injectors
turbosmart fpr2000 fuel regulator with gauge
competition black 100gph carter pump
2x044 700hp pumps
twin outlet 4ltr surge tank
braided fuel lines
nos fogger system 75hp shot
turbo bag
pwr alloy radiator
1000cfm thermo fan
jim berry custom clutch 4400pounds 4 puk solid center
r33 gear box
oil filter relocation kit
+ heaps more
bigger turbo setup:
6 boost manifold
billet t72q turbo
heat shield
progate 45mm waste gate
4" inlet with pod
4" dump pipe
the car made 488rwhp with standard head and ran 10.82sec 1/4, with 1.51sec 60ft, car lost traction at last quarter of track due to line coming off and sprayed oil on tyres and still did the time......
new engine ant turbo setup will make close to 600rwhp on pump, and over 700rwhp on c16 with more boost..... no money spared on the motor.....
kirk 0410757949
P1000363.jpg;)
Edited by grunter01
https://www.sau.com.au/forums/topic/294626-big-hp-rb2530/
yeah it was, and still is at the moment
may consider parting the setup if i get people wanting most of the parts.....
Mate I saw what you are asking for on CT.
Its a f%cking bargain. I am surprised it hasnt been snatched up already.
GL with sale anyway mate.
https://www.sau.com.au/forums/topic/294626-big-hp-rb2530/#findComment-4920198
  • 3 months later...
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
