hi folks,
after some of our guys only getting 2 runs on friday and the cressida not making it due to a log book issue, we have decided to bite the bullet and have a private test day on the 15th of november.
we have spots open so PM me if you are interested. the track hire cost $6600 so that works out at $550 a car for the 12 spots.
basically the first people to get in contact and pay for their spot are in. if you pull out its your responsibility to find some one else to take your place and get your $550 back.
gates open to competitors at 8am, then scrutieneering, racing form 10 am till 4 pm with no breaks. thats 6 hours of track time for 12 cars, $550 might seem like a lot but think about how many times you will have to tow to the track to get that much track time, it will cost far more.
Shane
shit shane, it looks like you have written $550 a spot lol.
hi folks,
Shane
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
