So my mate has a R33 RB25det manual.
Mods include 3inch cat back and turbo timer. Standard boost without going through the solonoid (7psi?).
Everything else its stock mechanical wise.
He rang me today and said once he got of the m7 doing the 100km/h speed limit when he back off in gear, very loud pops can be heard.
So I intially thought it might have been the normal popping sometimes associated with a bigger exhaust.
These are loud crisp pops and sound to be in sync. I mean pop...pop...pop... not pop......popopopop.........pop. Sort of thing.
Also now when starting the car it will stall unless the pedal is held for 5 seconds and then the car gains idle to 800-950rpm.
No check light has come on yet. Checked all vacuum lines, not leaks and everything seems to be in good working order visually.
Any thoughts?
https://www.sau.com.au/forums/topic/294703-r33-problem-after-highway-driving/
mine is similar except mine doesnt stall and the pops aren't in 'sync'.... when i get off the gas say at 6-7000rpm and revs drop to about 4000 it makes a loud pop + flame then a few little pops... i think its just the big exhaust (3inch straight through into 4inch muffler) + mine is running a tad bit rich hence the flamage..
edit: car is a series 2 r33
Edited by defari
Yeh this is deffinately not the over rich sound poping.
If you drive in 2nd @ 60 and back off the whole way on deacel its pops the same loudness like. Same sort of pop noise and its crisp not a rich sounding pop pop.
Check fuel pump and lines. if you gotta feed it to get the revs back so it doesn't die, and it's backfiring (usually a sound associated with not getting fuel - bare in mind it IS an rb25det with standard computer), then it sounds to be a fuel issue. fuel pump, lines, AFM could also be outta whack.
Backfire is generally excess fuel getting into the exhaust and being ignited by the heat. Since the injectors shut down at full decell, it must be a leaking injector feeding fuel during decell. Get the injectors cleaned.
It may also be that the injectors are not shutting down, and that is usually a result of the TPS getting out of whack and not sending the "throttle closed" signal to the ECU. Check the TPS for 0 ohms at "throttle closed".
OK quick ecutalk scan showed:
tps: .12v @ idle, 4.3v 100% throttle
afm: 1.2v @ idle - forgot 100%
02 is deffinatley stuffed. it sometimes adjusts from .20 to .40 but mainly sits on .00
Would the ecu see this as lean or would it ignore if tps and afm read full throttle.
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
