  • Replies 164
hey buddy have you managed to take out the Series 1 Airbag steering wheel ? currently waiting so i can buy it : )!
sorry mate havent been back long and been flat out but will make a start on steering wheel tomorrow
Is the Trust front lip still available, if so could you post up pics please. Very interested, can pick up this week if still available. Pm me with details please
Does the RB26DETT come with everything, i notice the tranny is not listed on the list? Is that cause your selling the engine with the gearbox?
If you are i would be very interested in taking it off your hands.
  • 1 month later...
Hey mate,
I live not very far from you, am looking at possibly getting a replacement steering sensor (mounted just behind the wheel)
How much would you ask for it? May have a look at what else you're selling if I could drop in.
Edited by J_Red33
Wondering if the following 4 items are still available?
  • 400R fibre front bar (GTR indicators)
  • Gearbox
  • Side mirrors
  • Spoiler/Boot
Cheers
Edited by LexDelta
Hi Have you still got the Radiator?? Do you know if the gtr radiator will fit a gtst?? Sorry I'm not sure if it will fit my car. Are you able to post it??
    • I have one and it was at ~43.5PSI.
    • Put a pressure gauge on the fuel rail.
    • I've uploaded logs / the current map to Gdrive if anyone has any ideas. https://drive.google.com/drive/folders/1FPnr22Z-EilG7tYdHSi0Qb07P2jfFLKV?usp=sharing
    • I'm running a Haltech Platinum Pro with the stock map for the RB20DET + tweaks for my build. When I started it this morning, the IAT was at 32F/0C (Outside temp was ~42F) and the AFRs went off the scale for my AEM gauge. I let it run for ~30 seconds then turned it off. I then did a smoke test, by hooking into a vacuum line directly behind the throttle body, and confirmed there was no leaks ( i let the smoke tester run for ~5 minutes / confirmed it was generating smoke before hand ). I then started the car again, after fixing a power steering leak.... and it seemed to be happy for ~30 seconds (was at ~11/12), but then seemingly shot back up to ~18 again. I then let the car run for a few minutes, thinking this was just cold start related, but the AFRs never came back down. I didn't let the car fully warm up, so maybe this makes sense, but I'm not sure what to do? The AFRs, when I last ran it, were normal, but because of personal reasons I haven't been able to break in the car. It was rebuilt last year. Engine / Mod list: Supertec pistons Spool rods Kelford 270 cams and Springs Stock crank Deatschwerks 900cc injectors Walbro 255 (Wired directly to the battery relocated in the trunk) NKG Audi R8 Coil packs + Conversion Harnesses from Wiring Specialties Holset HY35 turbo Haltech Platinum Pro ECU Haltech boost controller (wired in for high boost RB25 Neo transmission + needed bits for the speedo to work
