Okay, just got myself sent to regency..
The 2 things I got defected for were missing front bumper (Was gonna happen sooner or later, waiting for a new one) And my blowoff valve.
Now, the thing I don't get is that apparently the blowoff valve is not meant to release gases into the atmosphere... Umm it's a stock blowoff valve so how the hell do I get it not to make noise?
I don't think it's possible, only thing I can think off is run everything off the wastegate...
But does anyone know how to turn them down, or is the cop a retard?
https://www.sau.com.au/forums/topic/294744-defect-help/
1. Have you used the search function rather than go straight out and start a new topic? This has been covered dozens of times before.
2 .You shouldn't be being sent to Regency for 2 defective items - should be a cop shop visit. Go to your local cop shop and complain about the defect notice, then make a personal complaint about the officer for being a tosspot.
3. Factory blow-off valves are legal, as long as the return plumbing is intact.
https://www.sau.com.au/forums/topic/294744-defect-help/#findComment-4916318
Didn't think about searching a topic, sorry :P
And I might use that idea, go to the cop shop and complain about it.. But the cop didn't look at the blowoff valve, it was the noise he was complaining about.
https://www.sau.com.au/forums/topic/294744-defect-help/#findComment-4916324
they can send you to regency for 1 item if they like it's up to their discretion and will depend on what the defect is for. The 3 defect thing is that if they find 3 or more defects then they have to send you to regency.
What do you mean by this?
And if it is still the factory BOV and it still have the hose running back to the intake then you will be fine for that, but really you shouldn't have been driving around without a front bar.
Edited by D_Stirls
https://www.sau.com.au/forums/topic/294744-defect-help/#findComment-4916325
why shouldn't he be defected for no frontbar???
you are an idiot for even driving around without one, it was bound to happen sooner or later
fair enough going down to police station and complaining about the standard blowoff valve but when they see u got no front bar they are just gonna LAUGH at you
https://www.sau.com.au/forums/topic/294744-defect-help/#findComment-4916335
Yeah I know the front bar was bound to happen sooner or later, waiting for a new one to be ordered.
Was just making short trips, to and from work.. And this one was to the servo.
https://www.sau.com.au/forums/topic/294744-defect-help/#findComment-4916339
A mate of mine told me you can take the valve out, and run the turbo straight into the wastegate.. Not entirely sure about it.
And I told the cop it was stock, twice.
You do know that BOV and waste gate are used to achieve different things. Legally you need to retain both, although the ADR's don't state anything about a force inducted car needing a BOV (although they will claim it's a emissions requirement), but hey it's not like regency don't make the rules up as they go.
Edited by D_Stirls
https://www.sau.com.au/forums/topic/294744-defect-help/#findComment-4916351
there is a defected thread in regards to all the questions, answers and issues with defects mate....thats a fair defect IMHO as no front bar posses risk to pedestrians apparently....if you run one over....
as for the BOV part just dont worry about it mate....the cop defected you because it made some noise ahh well its standard and its supposed to
https://www.sau.com.au/forums/topic/294744-defect-help/#findComment-4916619
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
