Yeh had to do this to install my rear speakers.
As Johno said, there are two bolts under the bottom of the seat, the bit you actually sit on, undo those first. Remove that part of the seat, and then there are two bolts holding on the backrest part of the seat. Undo those and you can remove that part. This bit is a little tricky because of the seatbelts, you can either undo the seatbelts, or if you are like me and don't wanna mess around with that, just thread the seatbelts throught the eyelets until the backrest is as far away from the boot as possible
