1999 R34 Gt-t
Hi Guys,
I am thinking of selling my pride and joy. Have just had a baby and the wife's Astra just won't cut it as a family car so it looks like I may be purchasing a VE SS.
Extremely sad to see this go as I love this car more than life.
The car is extremely quick and is running 237rwkw with the potential for more. I have got the dyno graph. With a highflow cat and some more boost I was told could easily do 270rwkw.
The car looks extremely stealth and I never have any issues with police. I have never dragged the car or put the car on the track.
It is mainly a Sunday car for me at the moment, and like I said the only reason I am selling is to purchase a family car.
I am the first and only owner of the car in Australia and have had the car for a year and a half.
Price: $25500
Phone: 0415713337
No joy rides guys.
Haven't got pics yet, but will put them up when I get a chance.
Number plates are GTT-034 and I will be keeping these unless we come to sme sort of agreement.
Car Details:
Color: Red
ODO: 66000kms
Model: 1999 GT-T
Factory Options:
Nismo S-Tune Suspension
Nismo speedo cluster
Nsimo triple gauge cluster
Nimo front/rear bar + side skirts
Sunroof
Moifications:
DVD player
Apexi RSM
Turbo back Trust exhaust
Stealth front mount intercooler
18 inch wheels (18x8.5 fronts and 18x9.5 rears)
Tinted windows
Excedy Heavy Duty Street Clutch
Short Shifter
Nistune modified ECU
550HP Turbo
550cc Highflowed injectors
Walbro fuel pump
Z32 Air flow meter
 Share
    • Pretty simple question. I was about to put the transmission back in and thought I pretty much had it lined up when I noticed it seems like the pressure plate isn't flat. I was pretty careful when undoing the bolts both during initial disassembly for cleaning and when torquing them up for installation so this is pretty discouraging. I'm not sure if I accidentally bumped the pressure plate with the input shaft and bent it somehow or if it just showed up this way. Is it possible that there's just something obvious I'm not doing correctly? I'm pretty sure I was extremely careful to make sure the friction discs were seated correctly in the hub, everything lined up, flywheel torqued according to sequence, the little springs all sitting correctly in their seats, etc.  What's the play here? Do I jump straight to a new pressure plate?
    • OK. I can see that being the case. But if you live in the land of "only switching between 4.08, 4.11, 4.36" like most Skyliners, then you never encounter it. Now I perhaps understand why the crownwheel is thicker on some of the smaller numerical ratio diffs. The two stubs being the same (unequal) lengths and just swapped side to side between the different cases is a new one to me. I'm hating Nissan R200s more than ever now.
    • Reason I say this is I have seen broken ones, in drift, drag and even behind a stock Z. I do appreciate most of the time its the synchro's that go.   Trouble with quoting HP is it doesn't really say how strong the box is.  I've not seen many CD00X box's make it past a mid 9(150mph) I have seen about a stock R33 RB25 box's run a 9 too, they all go boom at some point though.   Another clue is they make gearsets for CD00X box's too, wouldn't be a market if they didn't break or have a limit people are going past.   I totally agree it is a strong box, just have to weigh up the true total cost of the conversion vs rebuilding with a good gearset.
    • What makes you say CD009 boxes are not as strong as you would think? I've always been told the last revision (CD00A) is good for 1000whp and I have no issue's believing it when comparing one side by side with an RB25 box. Makes them look tiny.
    • I picked up an open Center with shafts. I was told the Open shafts will fit a mechanical LSD and looking at them. I think they will work. Will update
