  • Replies 60
Dean, What was the 2nd defect for?
All this crap is the reason im getting a 2nd car to drive around in, then i can then spend lots of time working on the car making it illegall and then a small amount of time driving it because i would never drive it in popular places anyway.
SKYLINED yes but not as likely, 9krpm, appologies also - at least you found someone who can tune your ECU.
Out of interest, how is your getting the car complied going? Should approach CAPA and see if they want to finish the developement for approval so they can sell the kits. I have actually been told it costs them in the vacinity of 50K to get one of their setups sorted and approved.
Thanks steve. Don't worry about the thread...it's fun to read what you guys like to share anyway :D
My car just spun the crankshaft bearing yesterday.
I will be doing a major engine upgrade soon, depending on the cost involve. My setup wont be "standard" or ideal for capa anymore. They were keen but were not that keen when I discussed this with them a while ago and it does not seems that convinience for me.
I will try to get compliance via interstate route when my car is back on the road.
You need to ask why it spun the bearing in the first place. Normally with a Honda its got a lot to do with oil surge rather than rod loading. Have this looked into very carefully before going ahead with any rebuild, or it may just happen again
Fortunately PCOTY is still alive and kicking after Mallala :) .... sorry to hear about your beast Dan - that sucks. I take it you got a new supercharger belt and then this happens .... what a damn shame.
9K, Sorry to hear about your probs, your car is a weapon
Fortunately PCOTY is still alive and kicking after Mallala  ....
Hoy hoy, mallala killed mine,. 1 burnt out turbo base gasket, 2 x front brake disks with large cracks and a cracked exhaust manifold!! half decent lap time though maybe? haha :D
Thanks for all the support guys
I think Mallala killed me too. I was contemplating on a couple of good laps with a few easy lap in between. However those porsches distracted me :)
Oil temp went up to 134 C
Drove around for a week with this oil :) because I did not have time to get the oil or change it :cheers: (Now I pay for the consequence :))
Change oil and supercharger belt on Sat. Went to Victor Harbour with the slick tyres. Close to redline in most gears. Found bearing noise when I got there :(
After I got back I found that the car was running on 3 cylinders. Compression still good. Noise from cylinder 2 bottom end.
Engine will come out this weekend for examination. Can any one give me suggestion on who is good at building Honda engines in SA? My cylinders are oval shaped though. This may be a little bit difficult in SA :( I am looking at stroker kits, forge pistons, lower compression, higher boost, bigger injectors etc etc but it looks like a lot of $$$ though :(
BTW What are the use of cylinder sleeves?
It looks like I will be short of $$$ for the AEM. I will have to use the Greddy Emanage. Is there any good tuners for the Emange in SA? Martin can you look after me with this one too ;)?
damn sorry to hear about your S15 John .... that sucks ass .... oh well at least mine survived :D ..... lucky I only did the 3 sessions though I reckon - it certainly is HELL on cars!
By the sounds of it your engine oil turned to water and thus you lost the bearing. I take it you still run the factory fuel economy 5W-30 oil, and that kind of oil will not protect your engine sufficiently once the engine oil temps rocket. You should have been using 40wt minimum! I wouldnt have even driven the car once the oil temps went past 115C!! 134C.. pwoah....
Stuff like Redline with lots of Moly in the oil may have saved your hide. Changing the oil out after mallala would have made no difference if the damage was done. Or as Munro said, you suffered oil surge. Did you check your oil level before you went to VH?
Sorry to hear bro... Good luck with the new engine. I'd hate to think of how much the repair will be....
My friend who had a top end rebuild on a B18C got his done at Formula Honda. Of the mechanics is from japan I believe. He knows what hes doing...
9krpm, dont feel too bad, your not the first to destroy an engine on the track due to oil problems, wont be the last. Expensive lesson though.
Can I suggest you give some thought to an oil cooler before your next attemp to whoop more porshces around mallala?:D
How did you go keeping up by the way?
engine cracked open today
crank bearings ok
cylinder 2's pistons was slapping around for god know reason, cylinder 2 wall badly scratched :P We also found that the spark plugs were very loose. Just hand tighted. Spark plug no 2 was shaved. Damn Honda mechanic!!!!! Mallala did not kill me, SH!T honda mechanic did!!!!!!
-10w30 mobil 1 supersyn oil. busky I had no choice mate :) the 134C was a peak temp, my oil temp was roughly averaged at around 120C. Oil usually break down at 140C
-oil cooler on the shopping list ;) thanks for the reminder steve
Time for rebuild with forged internals, decopressed pistons and more boost :) See you guys on road hopefully not tooooo long :(
Hmmm was it detonation that killed your engine then 9krpm? It seems that way, by the sounds of it. Or your plugs werent cold enough. Shucks. Such a nice engine gone to waste....
I don't think it's detonation
AF has been tuned at 12.5 at the ezhaust tip (this is fairly rich because my car cat is fairly good)
The honda cylinder/piston is ovally shaped as well so normal detonation mark is not applicable to my car (I hope :D)
I think it's the oil :D
Busky, are you back aldready?
Nightcrawler, Out Law in town is having a sale on oil cooler. I am planning to get one and custom order the pipes from Enzed in wingfield
  • 4 weeks later...
    • If that's the wiring from the factory, I'd be inspecting the loom everywhere.   Any signs of that anywhere else, and seriously, I'd get rid of the car ASAP before the electrical gremlins make it worthless, or it goes up in flames on its own. That is scary how that insulation is failing!
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
