Hi Guys,
I'm looking at selling my car which is registered until March next year. It's a little bit rough in areas. I had intentions of putting in a RB25 in the future but my interests have changed. Runs immaculate.
1992 R32 Skyline with R34 frontend conversion. Wide body front and rear (Bee*R324)
Clear indicators
5 spd Manual
$50 Satin black paint job
Flush bonnet pins
Lenso D1R 18x10 -1 with 235/40 all round (Tires like new)
RB20DET with an RB25 Turbo currently on 12PSI (117.xxx kms. Major service done.)
Excedy sports organic clutch
Turbo back 3" Exhaust. (Have De-cat pipe not fitted)
Turbosmart bleed valve
Just Jap Alloy Radiator
Nismo thermostat (62 degrees)
Just Jap Front mount intercooler, also changed the rubber flexi intake
Apexi Pod filter and K&N Breather
Apexi SAFC2
Drift iridium Water temp and boost gauge
Drift button
Adjustable D2 Coil over suspension
HICAS lock bar
Shimmed diff
Front strut brace
Adjustable castor arms
Adjustable rear camber arms
R33 Brake booster
RDA slotted front rotors with QFM A1RM pads all round (780 degrees)
The only issues with the car are the gap in the bonnet where it meets the front bar which I have not had the time to get fixed. There is also a bit of a steering knock which I haven't investigated as it doesn't bother me or affect the driveability. I have a few of the standard parts which will also be included in the sale.
Located on the Gold Coast.
Will consider some swaps/part swaps. 11.5K ONO.
Pm me or post here. More pictures and information available on request.
https://www.sau.com.au/forums/topic/294781-1992-r324-skyline/
Are you interested in an immaculate silver 1995 series 1.5 R33 with only 89,000kms?
No thanks mate.
hi m8 do u jus wana sell your mags? and wea did u get your kit frm thanks m8
Not seperating. Kit was bought in Sydney.
thats phat mate.. ive always wanted somethin like that..
to bad im tryin to sell my cefiro aswell :)
Thanks, Your Cef is clean.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
