Patch Harness (sits between ECU and car Harness)
Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
This makes sense. I have 2 so I'll just choose the least favourable child to perform the task. If all turns to shit, I've still got a spare. Win-win!
The correct PPE is to get one of the kids to spin it while you film from a safe distance...
When they're so hard you can't leave a black mark or make any smoke...
By DraftySquash · Posted
That was at 11.6 PSI. Apparently it was already peaking around 9 PSI just from intake and exhaust mods.
