Black R32gtst - Sydney
I have for sale a Black, manual R32 GTS-T 1990. 103000K's on the Clock.
It drives nicely and is a firm ride with the Nismo setup. 100,000k service was done at 82000k. This included Timing belt, waterpump, thermostat, seals changed. Also recently (as I replaced the spark plugs to the copper iridiums) I have done a compression test and all the cylinders fall between 150-160psi.
The Oil (Penrite) and Oil filter (Genuine Nissan) is always changed every 5000ks. Fuel Filter changed every 15000ks. The O2 sensor has been replaced 25000k's ago. Always use BP Ultimate fuel. Car is garaged most of the time.
The Mods include:
- Apexi POD Filter
- ARC Intercooler
- AVCR Electronic Boost Controller
- Nismo shocks and spring package
- Front Eurothane Caster Rod bushes
- Strut Brace
- Mines ECU
- Slotted Front Rotors
- 3 Inch Cat Back – Exhaust
- 19 Inch Rims with Federal Tires all round
Interior
- Pioneer Headunit with remote control
- 6.5" Split Front Speakers
- Blue Neons under footwells (Turns on and off automatically when the door open/closes).
- Mongoose 3 Star Immobiliser alarm – Keyless entry
I'm after $9500k ONO as is. If you are serious in looking for a decent r32, I suggest you look at the others in the market and then afterwards come see mine.
I'm located near Surry Hills. PM me if you are interested and we can arrange a viewing.
Andy
Edited by BLACK_Rb20
  • 4 weeks later...
  • 1 month later...
  • 4 weeks later...
  • 2 months later...
hey,
I am interested in your car. I would have PM'ed you but I dont have enough posts yet. I have a honda prelude so usually post on prelude australia forums lol.
I would like to know a couple things first though..
Have you ever got it dyno tuned before? And if so what power did it put out?
It looks very neat and clean. Was wondering if you had any pictures of the interior and seats though?
Think it would be possible if I could come up this week and inspect it? I live down in Wollongong.
Let me know :)
 Share
    • Looked at ConceptZ HKS exhaust i just find $1000 shipping sounds crazy. and that was USD so $4400+ after AUD conversion thats the exhaust and shipping. just seems crazy is there anyone else in Aus that sells any of these exhausts?what about these will they fit they say up to 2016 though mines a 2020 just wondering if they will fit?
    • Im thinking of getting some new wheels soon so i might keep a stock in the boot some how if i can fit and secure it. i will just buy a scissor jack from supercheap aswell. thanks guys. might even see if i can find a space saver just to get me out of shit.
    • Oh also, looks like it will be 3-4 weeks before they arrive - so no coolant change until then 😕
    • @soviet_merlin Managed to find my part and get it off Amayama. While I was at it and paying 9.75 AUD shipping for a $1 piece, I thought I may as well get some other plastic clips I broke 🙈  Thanks a lot for this link
    • The point of all that for me was to get to the PDM (yes, v37 is as fancy as a haltech) which is between the battery and the front inner guard.  In there, pins 80 and 81 on connector E125 are for hi beam according to the USDM manuals. I chose to intercept the high beam signal there as it is next to the battery and firewall so it is a good place to mount the fuse/relay for the LEDs. Unfortunately because you can't access the PDM with the battery in the car, it is difficult to test those wires are correct. The fuses for Left and Right high beam are marked on the PDM cover, so I checked continuity from the fuses to those pins with a multimeter, and it seems to be right. From here I need to splice a wire into one of those 2, and run it into the cabin for a switch, then run the trigger wire back to that general location for the relay. So, I removed the driver's side guard liner to check out where the wiring leaves the engine bay and enters the cabin.  Turns out, that does not happen behind in guard liner at all....waste of time, nothing is routed through there, so that was another 5 pin clips, 4 screws and a bolt of wasted effort All of the wiring is actually run across the separate compartment between the engine bay and the cabin under the cowling...so off with the windscreen wipers after all....
