Have been looking on just jap and am planning on buying this: http://justjap.com/store/product.php?produ...=276&page=2
Dont know too much about the different brands/which ones to avoid / etc so hope fully you can help us out with that
Also Planning on getting this cat: http://justjap.com/store/product.php?produ...=275&page=1
On another note, whats the difference bewtween these two products performance wise? Is one better flowing then the other? http://justjap.com/store/product.php?produ...=339&page=1
or
Thanks for any general feed back, will be apreciated.
https://www.sau.com.au/forums/topic/294850-jjr-products/
sup man
yeah i have the jjr 3in front dump pipe and the xforce cat i got off them too.... fitted up sweet and i have had no issues with good power increase.
how ever i have never tried other exhaust set ups so i couldnt really compare.
catch ya
https://www.sau.com.au/forums/topic/294850-jjr-products/#findComment-4917904
used quite a bit of thier gear over the years and been very happy (cranks, intercoolers, oil coolers, hard pipes etc) the only things ive had dramas with is the radiators.
Edited by URAS
https://www.sau.com.au/forums/topic/294850-jjr-products/#findComment-4917913
Thanks all, exactly what i wanted to hear.
@ R31Nismoid, sorry noticed straight after i posted that they are a sponsor. And yes i do search but sometimes its quicker to ask then too spend hours shuffling through random pages looking for an answer.
https://www.sau.com.au/forums/topic/294850-jjr-products/#findComment-4919733
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
