First of all mods please dont remove as the car is a drag car hence why i posted in drift/drag
1993 gtst skyline drag car ready to race just needs an engine package
minitubbed to fit 28x 10 rear tyre
gtr rear subframe & diff with new subframe bushes
full spool diff centre diff has been completely rebuilt
new front & rear brakes
new rear rims with near new slicks
new front rims with front runners
custom tailshaft
powerglide transmission ,6000rpm converter, billett th400 input shaft,transbrake,b&m supercooler,b&m shifter ,flexplate, makes boost in under 4 seconds with rb26/30 & gt42r
solenoid shifter
lexan windows all round
fibreglass bonnet
gtr front guards
stretched rear guards
andra 6 point roll cage with new sfi rollbar padding
sheetmetal dash with boost guage/shiftlight tachometer & warning lights
momo carbonkevlar race seat
simpson harness
diest parachute
custom fuel tank
custom puke tank
pwr radiator
gel battery
car has been completely rewired m800 loom done in techflex
comes with plenty of spares engine parts also available at extra cost
weight was 1136kg with all fluids
may separate wheels / trans for cheaper price
price is $15 000 roller minus engine/ecu/cdi
contact Jason 0424348521 or pm
https://www.sau.com.au/forums/topic/294851-slo32/
car is also available turn key or with unassembled engine package,with motec m800,with cdi ignition at additional price
engine rb26/30
new crank nitrided balanced etc etc
block machined 010 grout filled 3/4 (still fine for street)
new argo rods & spares
new cp pistons & spares
arp rb26 head studs
crank studs
jun oil pump
ati balancer with dry sump drive & crank trigger
custom cam trigger
head machined 272 cams psi springs ferrea valves ported
custom intake with 12x 1600cc injectors 100mm throttle body motec 5bar map
hks exhaust manifold with 6x egts custom gt42r & 55mm gate
ecu motec m800
cdi msd dis4ho 3x motec twin coils top gun leads
fuel system new aeromotive belt drive pump & reg with braided lines & fittings
& many spares
Edited by jas/slo32
https://www.sau.com.au/forums/topic/294851-slo32/#findComment-4937240
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
    • I really don't understand the point of aftermarket oil pumps if your particular engine doesn't need more oil pressure. As far as I can make sense of it the problem seems to be cavitation from sucking air, maybe the pump gear design with how it interfaces with the OEM crank, and maybe the backing plate screws wanting to loosen themselves. How does flowing more oil fix these issues?
