wolf 3d v4 plug and play ecu to suit r33,selling because ive sold my car, uses map sensor so you can elliminate that shitty air flow meter
has a tune on it atm tuned for a series 1 with 550cc injectors big turbo and good fuel system with 2 bar boost
$800 frim
ben - 0423266657 sms or call because im not on here much
https://www.sau.com.au/forums/topic/294873-wolf-3d-v4-plug-and-play/
  • 3 weeks later...
  • 3 weeks later...
hey guys still forsale, person who was buying my car fell out so i was going to keep it but yeah things have changed so its still up forsale, i also have a brand new wolf intake air temperature sensor and plug to suit this ecu, so its plug and play just need tune to suit you car - ill still sell for $800
thanks ben
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
