4WD light on dash cluster is on all the time. Has been since i bought the car. Didnt think anything of it until lately.
Was wondering if it was normal or if it might be indicating a transmission fault. Car seems to drive fine.
Any help much appreciated.
https://www.sau.com.au/forums/topic/294910-m35-stagea-4wd-light-on/
check the attesa fluid in the boot, its behind the hidey-hole on the drivers side. i bet you the fluid is low.
+1, this was my first thought. That little cubby was a bugger to get out in mine, thought I was going to bust it, then it finally popped free.
ahh good, thanks for letting me know that. ive never taken mine off, i should because i get the 4WD light sometimes (must be fluid, only happens on inclines)
the book lists the g-force sensor as a potential fault, fluid, make sure the 'S' light appears next to the 4WD light on the dash if you move the switch.
also check the plugs to the attesa ecu which is next to the fluid bottle
where abouts is the bottle? lol i had a quick look but couldnt see anything
It is in the boot. On the right side is a small hatch on the side wall (similar to the one on the left). To get to the attesa bottle you need to remove the front cover and the whole side compartment (black plastic inset). To remove this it is easiest done with a small (thin) screwdriver or similar. There are latches in the top corners of this inset box. By pressing down on the top of them you will be able to pull the box out. You will the see the Attesa bottle.
Good luck
Andy
After 6 months ours started displaying the 4WD warning too. It is never on just after start-up but will display anytime within the first minute. Usually if it doesn't come on within a minute it won't come on at all.
So I bled and replaced with Matic D in the Attesa system and replaced oils in transfer case and both diffs. Problem remained.
Sometimes I can sense that the warning light is about to display. When driving away the car will bind up slightly and want to straighten up - like as if the centre diff is locked and the fronts what to rotate at the same speed as the rears. The warning light will come on, the steering will relax, and I guess it then is a rear-drive only?
Also, if the car has been allowed to fully cool then the warning light won't display but is very likely if the car was recently switched off.
My next attempt will involve reading those fault codes.
  • 4 weeks later...
  • 4 weeks later...
put the car on our scanner at work and it displayed a 4wd motor fault. im guessing this is the pump motor in the boot. Can anybody confirm this.
Yeh pretty sure it's under the back on the RHS .....right behind the rear wheel.
P.S. Any chance I can get on that scanner......I think I may have the same problem :D
Edited by Jetwreck
sure, no problems, just give me a call. 0425 349 923
P.S. Any chance I can get on that scanner......I think I may have the same problem :(
  • 3 months later...
I have recently had the same problem on my NM35.
My 4WD light was coming on after a few minutes of driving. This then turned into every time i started the car the 4WD light would be on.
While the 4WD light is on the ATESSA is not active so it will be running in RWD.
The problem end up being (after a long time troubleshooting) a relay located under the air filter. This relay controls the ATTESA pump. Without the pump no 4WD.
This relay in not available threw Nissan anymore so i had to addapt a generic 40A relay.
This has fixed the problem completly and 4WD light has not come on again and ATTESA is working perfectly.
I have attached some schematics that helped me out.
I hope this helps someone out as i spent ages figuring this out.
Cheers
  • 5 years later...
Cheers
Thanx sooo much for posting this. It fixed my car. I bought my car from a Sydney Importer & the 4WD light came on 2 weeks after I got it. His Mechanics looked at it once then they told me to go somewhere else the next time. I found this and took the car to my mechanic, who checked through the whole system then the relay and it was dead. He wired in a 40A generic and BOOM attesa pump fired up and no light.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
