Anyone In VIC Installed A "Patrol" Clutch??
gtstii
 Share
hey all,
I've researched a little bit about these Nissan Patrol Clutches which heaps of people have used and are meant to be a straight fit into a skyline, stronger than stock and feel quite ood (as I've read)!!
Has anyone in Vic installed one of these?
What do you think of it if you have?
I was thinking of getting one, cos if they are good, I can get them for $200 and install for $250 - $450 for a brand new clutch is a sweet deal! :D
Ive heard that you have to specify "heavy duty" when you order the clutch or else you just get the normal one. I think I heard this from max? not sure though..
I've had it done.
Yes, the part no. is R173N, get the Heavy Duty version, its a little more but def worth it.
The clutch feels great, actually lighter feel than the stock one
Not sure about the R32 GTR, but I remember reading that it uses the same clutch as the R33 GTSts...
  • 6 months later...
I've had it done.
hey maximus, where did ya get yer clutch from?
  • 1 month later...
Sorry to drag up an old thread, but I just tried to order a Patrol clutch from 3 Nissan dealers, and all of them said that R173N was an invalid part number. It was probably for an aftermarket clutch they said. Does anyone have the exact details of the clutch (or a serial number that works) so I can order it?
Thanks,
Michael
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
