To Mod or not?
54 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I have a question to ask you. I have a pile of gear ready to go on the car (list below) and I was always intending to get a workshop to do all of it simply because the dump pipe for the new turbo would have to be made to fit as well as the oil and water lines etc, but now, I've bought all that together and it should all bolt right up!
So my question is:
Should I save up and get a workshop to take care of all the hassles for me, or should I spend time modding the car myself like I have done so far and always wanted to continue doing? This would be a great way for me to learn things that I didn't previously know, and to cut down on costs.
Couple of pointers:
I don't need the car to run at all for at least 8 months when I may or may not be moving, so the time factor is void.
I figure myself to be quite handy with stuff and can handle a spanner pretty well. Electrical things I'm more then fine with.
I can configure the ECU changes myself.
Now, the list of things to be installed are:
GT3076R turbo
Split Dump to suit
Oil and Water lines
Greddy Front Facing Plenum
Large Throttle Body
850CC Sard Injectors
Poncams
Cam Gear
Timing Belt and Tensioners
Hicas Lockbar
PFC Boost Controll Kit
PFC Datalogit
Bosch 040 Fuel Pump
Oil Filter Relocation Kit
And optinals:
Fuel Pressure Regulator
ATI Harmonic Balancer
So, should I take the plunge and start undoing every bolt in sight on the weekend, or give it to a workshop to save the hassles? :D
https://www.sau.com.au/forums/topic/294965-car-modding/
  • Replies 41
GT3076R turbo (Do yourself.)
Split Dump to suit (Shop.)
Oil and Water lines (Do yourself.)
Greddy Front Facing Plenum (Do yourself.)
Large Throttle Body (Do yourself.)
850CC Sard Injectors (Do yourself.)
Poncams (Shop.)
Cam Gear (Do yourself.)
Timing Belt and Tensioners (Do yourself.)
Hicas Lockbar (Do yourself.)
PFC Boost Controll Kit (Do yourself.)
PFC Datalogit (Do yourself.)
Bosch 040 Fuel Pump (Do yourself.)
Oil Filter Relocation Kit (Do yourself.)
https://www.sau.com.au/forums/topic/294965-car-modding/#findComment-4919512
Dave, split dump already exists, can be bolted in with the turbo and the exhaust manifold... that I forgot to mention... knew I would forget something!
I was thinking I would leave the cams, cam gear and timing belt for a workshop simply cause I don't have a timing light. But I might be able to get one... and someone that knows wtf they're doing :D
https://www.sau.com.au/forums/topic/294965-car-modding/#findComment-4919522
Most of the stuff there could be completed in a day or two with a few mates provided there's not too much booze involved.
You may need to buy a few tools but it sure as hell won't cost anywhere near the total from a workshop.
Moreover, you can say you built it yourself (or with mates) which is much more than what most people can say.
https://www.sau.com.au/forums/topic/294965-car-modding/#findComment-4919532
It depends to you have the skills to pay the bills if you stuff it?
Being a competent mechanic takes time, hence the four year apprenticeship, but who am I to judge take the plunge it will at least make for some good reading lol.
I think you would be better off working overtime or getting a extra job for a little while and get a work shop to install the below:
GT3076R turbo
Split Dump to suit
Oil and Water lines
Large Throttle Body
Poncams
Cam Gear
And you could do the following:
Hicas Lockbar
PFC Datalogit
Bosch 040 Fuel Pump
PS i voted for boobs.
https://www.sau.com.au/forums/topic/294965-car-modding/#findComment-4919716
Chubbs, oil relocator will be a piece of piss without a plenum in the way :laugh: Hicas lock bar though you're rght, but that's a simple job in itself.
BOZ22N, to be honest, I do really want to do it myself, it will feel so much more rewarding in the end. If I come to a point that me or my friends (some being full time mechanics) then there's a workshop that I trust dearly just down the road. That's who would be doing the work if I were to pay for it, and while it would be done quickly, that's not really what I'm after. The car LITERALLY hasn't moved since Texi so it's not a big deal if it takes me 3 months to complete. And it's not so much the fact that I don't have the money (which I don't right now anyway thanks to buying 3 turbos), it's more the fact that I would really like to take on the challenge and see if I have the skills to complete it.
I'll leave the poll running for a bit and talk to mates that I would rely on if something were to come up that I couldn't achieve and make a choice from there :D
I always knew boobs would win, they win everything.
https://www.sau.com.au/forums/topic/294965-car-modding/#findComment-4919927
