MBS206 Posted November 5, 2009 Share Posted November 5, 2009 Doof: Let me put it this way... I'm an office worker... Yet I've done gearbox CONVERSIONS (Auto to manual) And a couple of engine swaps now... I can rip my turbo and exhaust manifold off in under 60 minutes, and give me another 60 and I have it all back on and bolted up tight ready to go. Inlet manifolds are piss easy too, as are cams, and timings belts. Cam gears are just as easy. Piss off the fuel pressure regulator, the factory one will handle it so long as you're keeping the factory rail (It removes one more headache!) As long as you read the workshop manual for installing things like the timing belt, exhaust mani, inlet mani, and cams, (Tightening patterns etc) then you won't have a single problem. Everything you have there is direct fit shit. Quick adjust ment on the ECU to get it starting, and head to the tuner... Really, for a slow worker, and some head f**ks, that's a 2 weekend job... (4 days) I would advise, go and buy all new tensioners, idlers and bolts for the timing belt, as well as the bolts that hold the cam caps down, and the exhaust manifold studs, you want the shortened ones. Also, I have a timing light you are more then welcome to borrow. (Hey, I'll come and spin some spanners with you too if you want!) But seriously, do it yourself! Oh, and my experience on the liner ranges from: Radiator changes, to timing belt changes, to changing heads, to swapping manifolds (inlet and exhaust) to swapping whole motors... I know my way around an R33 engine bay backwards... In fact... i've spent about 10 times more time in my engine bay then driving the car lately (I just keep changing shit of late) Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4919960 Share on other sites More sharing options...
evil_weevil Posted November 5, 2009 Share Posted November 5, 2009 Well, I think a hoist would make it easer, but thats just me doof. knock yr self out having fun.. Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4919983 Share on other sites More sharing options...
MBS206 Posted November 5, 2009 Share Posted November 5, 2009 Well, I think a hoist would make it easer, but thats just me doof. knock yr self out having fun.. A hoist makes it a million times easier... But it's all doable on well positioned car stands. (Well positioned so the bastard doesn't fall off!) Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4920074 Share on other sites More sharing options...
MBS206 Posted November 5, 2009 Share Posted November 5, 2009 hicas lock baroil filter relocator would be easier to do from underneath, exhaust stuff just easier! Also, I'd do the oil filter relocator from up top... Once the inlet mani is off (It's coming off anyway) much easier access, plus the cross member and steering rack and engine mounts are in the way from underneath... And I'd love to see the hicas done from above... Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4920079 Share on other sites More sharing options...
craked Posted November 5, 2009 Share Posted November 5, 2009 mate if your not keen on paying the big workshop bill i can help you at alot smaller cost just another option Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4920135 Share on other sites More sharing options...
nIsMo86 Posted November 5, 2009 Share Posted November 5, 2009 DOOF... I also agree you should do it yourself. You will feel good that you modded your car yourself. I have always done all my mods and work myself on all my cars since i have gained the knowledge. The stuff you are planning to do is fairly easy. As for the poncams and timing light...If your motor is already timed correctly prior to installation, you can just set the motor on tdc and mark the cas's location. Put everything back exactly how it was after install and away you go...timing will be the same. If you need any help/advice with it, feel free to ask. Ive done all these mods before. PS. Boobies ftw!! Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4920153 Share on other sites More sharing options...
DRD-00F Posted November 5, 2009 Author Share Posted November 5, 2009 If you're willing to do a house call to Hornsby then I just might give you a call some time With any luck though, it should all work out all good but who knows! Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4920177 Share on other sites More sharing options...
l_uk3y Posted November 5, 2009 Share Posted November 5, 2009 Only time you shouldn't give it a go yourself is if you don't have the time or the tools to give it a proper go. As long as you have those two things then i vote give it a go yourself Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4920290 Share on other sites More sharing options...
Liz Posted November 5, 2009 Share Posted November 5, 2009 doof, do it yourself if you're handy with a spanner. the way i see it.. 90% of the work i've had done on my car had to be re-done because someone stuffed it up.. so i literally paid for it twice so if that's the case (as it more often than not, is) why not do it yourself hten take it to a mechanic if you stuff it or get stuck lol plus you'll feel good about it Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4920404 Share on other sites More sharing options...
Kramotax Posted November 5, 2009 Share Posted November 5, 2009 Agreed, start with the less headache job and see how you go towards the more difficult ones.. Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4920447 Share on other sites More sharing options...
nIsMo86 Posted November 5, 2009 Share Posted November 5, 2009 If you're willing to do a house call to Hornsby then I just might give you a call some time With any luck though, it should all work out all good but who knows! Yeah no worries, if you get stuck with anything i'm willing to give you a hand. Just drop me a pm. I work near hornsby anyways at suzitech in thornleigh. But from what knowledge you say you have, i'm sure you'll be fine. Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4920661 Share on other sites More sharing options...
FloydWestwood Posted November 5, 2009 Share Posted November 5, 2009 cams is the easiest bit. Do the lot yourself. If you have some leave from work, allow yourself 3-4 days to do it all. Probably just a weekend if you know what your doing. Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4920751 Share on other sites More sharing options...
Pezhead Posted November 5, 2009 Share Posted November 5, 2009 If you do the Hicas yourself you can borrow my 30mm spanner. I did the project myself only to find that I didn't have a spanner and the adjustable spanner wouldn't fit - was $62 bucks at auto one! Let me know if you need it. Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4920831 Share on other sites More sharing options...
Cassbo Posted November 5, 2009 Share Posted November 5, 2009 Only time you shouldn't give it a go yourself is if you don't have the time or the tools to give it a proper go.As long as you have those two things then i vote give it a go yourself Quoted for truth! Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4920914 Share on other sites More sharing options...
DRD-00F Posted November 5, 2009 Author Share Posted November 5, 2009 lol cass... wtf have YOU modded on YOUR car? You're an electrician and I made that rear light for you Also, I'll look at my socket sizes Pezzy, I don't think mine do go up to 30! Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4920989 Share on other sites More sharing options...
Cassbo Posted November 6, 2009 Share Posted November 6, 2009 lol cass... wtf have YOU modded on YOUR car? You're an electrician and I made that rear light for you That's a low blow sir, just because I thought a light up facia was some kind of engineering marvel of unexplainable complexity It's true, I haven't done much for modding cars, but I'm pretty stubborn about not taking it to a mechanic! In my R31 I: Replaced clutch master cylinder Replaced power steering pump Replaced water pump Replaced timing belt Replaced fuel pump In my R33 I: Replaced lower control arm Replaced tie rod end Replaced castor rod Replaced front bar Upgraded front and rear swaybars Installed 4 point harnesses Boost control solenoid grounding switch Voided warranty because I couldn't be bothered going to a mechanic every 5,000kms to do something I could easily do myself in an afternoon Please don't mistake this list for me saying "ZOMG I'm teh most bestest mechanic EVAR!" but seriously... if it bolts off and bolts on without much hassle why not do it yourself? As far as I'm concerned I'll take my car to a mechanic when: A. I lack the time B. I lack the ability 3. I lack the tools D. I can't find the fault Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4921278 Share on other sites More sharing options...
Aggroman Posted November 6, 2009 Share Posted November 6, 2009 Do it yourself.. I changed my brothers turbo, dump, front and exhaust on his S15 in one weekend only hard part was the damn oil lines... And it was the first time I had even looked at the SR engine. Hardest part with alot of them would be trying to get some of the bolts off after 10yrs or so. I have a semi decent tool collection if your ever in need of anything. Hornsby is kinda far away but if its for a good cause im sure i can make the trek, Doubt you will need it but.. Then after all the work is done, go to a titty bar Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4921386 Share on other sites More sharing options...
NZM.031 Posted November 6, 2009 Share Posted November 6, 2009 do it yourself doof.. there is nothing there that is even remotely challenging.. its all unbolt and bolt up.. i dont know why you'd even consider taking that to a workshop. you'll need a 30mm spanner for the hicas bar.. not a socket. and with all the threads on here im sure there is no problem that hasnt been covered before. you'll be right... hook in! Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4921552 Share on other sites More sharing options...
GoldZilla Posted November 6, 2009 Share Posted November 6, 2009 As far as I'm concerned I'll take my car to a mechanic when:A. I lack the time B. I lack the ability 3. I lack the tools D. I can't find the fault LOLs at "A... B... 3... D..." Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4921576 Share on other sites More sharing options...
Marsss Posted November 6, 2009 Share Posted November 6, 2009 do it yourself and make with the boobs already... Link to comment https://www.sau.com.au/forums/topic/294965-car-modding/page/2/#findComment-4921761 Share on other sites More sharing options...
