Xanavi Help On M35?
Hey all,
I got the M35 on Tuesday afternoon and have already put almost 300klms on it :D
I have a quick question, does the xanavi version of the navigation system have the economy leaf and so on? I can not seem to find it if it does. I had a look at the guys M35 around the corner (autech axis) and this has the normal Nissan program with the economy leaf.
Thanks in advance.
Cameron
all nav units are xanavi units?
im pretty sure
it's the 3rd button
then toggle with the stick
do you mean the 3rd button from left to right? and on the top or bottom?
thanks, ill give this a try :D
Hey guys, I tried the above advice but the third button did not do anything, it does not make a noise or anything. Also, from the photos I have seen of other peoples screens, mine is very different, it does not say nissan on it but has 'birdview' with all blue backgrounds and so on. There is only 1 screen that is the 4th button accross from the left on the top with any kind of info on it and it has only got a very basic compass and the rest of the info is these little graphs and so on.
Ooops, my error :)
When I jumped in the car last night, I noticed that it IS the 4th button across that you will need to hit.
The leaf is then the top right option.
Sorry about that Cam.
That leaf is pointless!! haha economy and m35.. does not go together
I guess you just have the wrong mods then! My fuel economy is through the roof on a standard tune.
Travelled 136kms last night... mostly freeway (ahem, tollway), but with some main road and residential in there too. Averaged 94kph according to the trip computer and 13.9km/L.
Which works out at 7.2L/100kms. :):):)
Will be putting up a post, with pics regarding this mod very soon.
Edited by iamhe77
Cam, you ought to put and exhaust gas temperature probe in your exhaust to make sure you do not lean out tooooo much.
I am looking forward to seeing the details of your mod.
Edited by andy65b
I will soon enough (I hope).
It is only when cruising that the economy is fantastic. When the engine is under load (accelerating) it actually uses more fuel than normal.
Think of it like a 1.5x (example) modifier... 1.5x fuel use when accelerating. 1.5x less fuel used when cruising.
Oh, and the throttle is a fair it more sensitive as well.
...the room goes quiet while we all wait with baited breath to hear about this new mod...
7.2L/100km. Thats DAMN good for any car!!
you serious?!
I realise you have a larger turbo and exhaust, both which will help...but even so, I had both of these (+tuning) on my previous stagea and even then it couldn't crack the 10L/100km mark on the highway.
Best I've seen from the M35 is 9.5L/100km and that was 100% highway, no A/C, constant 100km/h in 5th gear.
you serious?!
Very serious... actually scale that down to "quite serious". I don't like getting "very serious".
I don't have a dump done yet, so I don't know if that will aid or diminish economy.
Didn't have the A/C on, but I did have the climate control on if that makes any difference. (18 in cabin, 13 outside)
far out thats good, i can get 7.5L from the fiat on a bad run tho :(
Fanboy.
Maybe you should give your wife the Stag and just get around in your little Fiat :bunny:
Edited by iamhe77
i was getting 700 out of a tank to and from the snow..
so it doesnt sound like its going to help me all that much, whats needed is less fuel everywhere else on the map..
400-500km around town, i do drive rather quickly tho. tho its yet to bother me really
 Share
    • Suspension bush. Got urethane bushes in the upper arms?
    • thanks for heads up on actuators - will sort something as back up or solution as yes dont need that have enough trouble but no doubt some addition of something to spares boxes is required yes have a clue about WTAC but nothing has been officially put out yet so will wait to see exact details Pro class is, has been and will become a draw card for lap records and one off builds for show and thats about it I think - be interesting to see how open they make it Pro am is the old Pro in reality Open class will be split into 2 with slicks and 050's with no doubt slight variances in allowable drivers and changes in aero Clubsprint + apparently a true street class   They have to and are refreshing it all and bringing things up to current standards and need to 100% adhere to rules because whether people like it or not / or say it or not - for alot of competitors it is sheep stations and has been for a while when Im getting told I was illegal because i cut my rear bumper too high and yet others where in the grey areas of legality with everything from engines, suspension, ride heights and more serious influences it actually got quite out of control and heated this year so as much as I may be impacted by some of the changes and prob spit the dummy when I have to spend money changing things I think its a good thing for all
    • I can’t tell if it’s suspension related or maybe wheel bearing or motor mount.  IMG_6209.MOV
    • Start with a multimeter, and see if you're getting power at the TPS. There should be a manual for your car somewhere on these forums and it'll have the info for what closed TPS signal voltage is, and how it should sweep to full throttle. Same as for other sensors / valves.   Have you checked things like your base timing etc? See if anything looks amiss there too?
    • here are 2x options to consider: https://www.selby.com.au/price-promise/tonewinner-sw-d6000-subwoofer.html https://www.apollohifi.com.au/svs-pb-3000-ported-subwoofer-black-ash-pre-order.html I'm waiting for a good BF/CM sale and will pull the trigger on a new sub, I do like the SVS PB-3000 (13") but you could nearly buy 2x Tonewinner D6000s (15")
