Xanavi Help On M35?
i was getting 700 out of a tank to and from the snow..
so it doesnt sound like its going to help me all that much, whats needed is less fuel everywhere else on the map..
400-500km around town, i do drive rather quickly tho. tho its yet to bother me really
Similar to what I was getting Andrew... except a bit better around town.
Will let you know what I get to the tank on next fill and post it in the appropriate section... but 135kms for around 1/8 (max) of a tank?
With more power comes bigger fuel bills. If you want to reduce your usage, train the right foot not to listen to your brain. :bunny:
You can run lean at cruise to some extent but at full throttle you require either extra unburnt fuel, water injection or ethanol in your tank to control the piston temperature, unless you like rebuilding engines like I do.
Mmmm stripped 3.5 block would be nice. :(
Fanboy.
Maybe you should give your wife the Stag and just get around in your little Fiat :P
hahah thats exactly what happens, except she has a mercedes pick her up and take her to work (public bus)
No, I have a similar throttle controller and they do bugger all, only changes the throttle pedal resistance from linear to exponential.
yup they are useless, they only affect throttle input from the pedal, not the actual throttle opening in the throttle body
With more power comes bigger fuel bills. If you want to reduce your usage, train the right foot not to listen to your brain. :(
Mmmm stripped 3.5 block would be nice. :P
:D
I give you a year...
Hey Chris, unsure if I will be able to come up tomorrow but heres the photos of my xanavi screens for you.
Start up screen >
This screen appears when I click the button 4th from the left on the top row >
When I click the bottom option on the above screen, this is the compass that comes up >
Cheers
Cameron
nope thats a dealer fitted one. not the same as the factory fitted item. so the info above is useless to you.
would LOVE to have a fiddle with that one though.
Depending on what time your available tomorrow, I may still be able to make it up?
Would be good to discuss options for DVD + HD TV Tuner in my Stagea too. Do you still have the double din facia for the 07 Honda Jazz?
Cheers
Cameron
 Share
    • Suspension bush. Got urethane bushes in the upper arms?
    • thanks for heads up on actuators - will sort something as back up or solution as yes dont need that have enough trouble but no doubt some addition of something to spares boxes is required yes have a clue about WTAC but nothing has been officially put out yet so will wait to see exact details Pro class is, has been and will become a draw card for lap records and one off builds for show and thats about it I think - be interesting to see how open they make it Pro am is the old Pro in reality Open class will be split into 2 with slicks and 050's with no doubt slight variances in allowable drivers and changes in aero Clubsprint + apparently a true street class   They have to and are refreshing it all and bringing things up to current standards and need to 100% adhere to rules because whether people like it or not / or say it or not - for alot of competitors it is sheep stations and has been for a while when Im getting told I was illegal because i cut my rear bumper too high and yet others where in the grey areas of legality with everything from engines, suspension, ride heights and more serious influences it actually got quite out of control and heated this year so as much as I may be impacted by some of the changes and prob spit the dummy when I have to spend money changing things I think its a good thing for all
    • I can’t tell if it’s suspension related or maybe wheel bearing or motor mount.  IMG_6209.MOV
    • Start with a multimeter, and see if you're getting power at the TPS. There should be a manual for your car somewhere on these forums and it'll have the info for what closed TPS signal voltage is, and how it should sweep to full throttle. Same as for other sensors / valves.   Have you checked things like your base timing etc? See if anything looks amiss there too?
    • here are 2x options to consider: https://www.selby.com.au/price-promise/tonewinner-sw-d6000-subwoofer.html https://www.apollohifi.com.au/svs-pb-3000-ported-subwoofer-black-ash-pre-order.html I'm waiting for a good BF/CM sale and will pull the trigger on a new sub, I do like the SVS PB-3000 (13") but you could nearly buy 2x Tonewinner D6000s (15")
