I use it on my dump pipe. Stinks for 100kms or so till it burns off the bit of oil or whatever is in it. Many people say it's a waste of time. At the end of the day... there might be better ways to heatproof stuff like hpc coating for example but if you've got it already then might as well use it. Just use hose clamps i don't think they need to be anything special although they do sell specific ones but i think that's just because they're narrower. Only thing that you could do that you wouldn't have to fix down the track.
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4920264
thanks heaps bro
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4920373
steel cable ties or stainless wire does the trick. using heat wrap can create hot spots in manifolds tho and with some aftermarket units using it voids the warranty. in saying that i use it on my dump pipe and hot side intercooler pipe
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4920708
i used it on my front/dump pipe to help keep the heat down as best i could in the engine bay, im pretty pleased with how it turned out. the hot tip is soak the heat wrap in water for a minute or 2 before you wrap ya pipe, make sure it overlaps by 1/2 or 1/3. secure it with stainless hose clamps, and ya laughing old mate.
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4921650
Soaking it in water is a BAD thing to do... Heat wrap will trap moisture and rust the pipes...
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4922064
The wrapping dries out with the heat of the exhaust anyway, doesnt hold any moisture that would rust the pipes.
The best thing to do is paint the piping/manifold with high temp paint to seal it, then use the wrap.
Soaking it in water makes it easier to do a good install (nice a tight with good, even coverage)
Ive heard that wrapping isnt that good to use on stainless, but i used it on my extractors (when i was NA) and never had a problem...
Im using it on my steampipe turbo manifold and considering it on the stainless dump to keep engine bay temps down - dunno about the dump being stainless tho.
+1 ceramic coating is the shit, but VERY expensive, heat wrap does wonders for engine bay temps.
Also use it on my oil return line that runs very close to the exhaust, along with hotside I/C piping...
Oh yeh and use gloves when you install this shit, or youl be picking out invisible fiberglass splinters for weeks to come...
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4922612
Really?
I know a lube mobile mechanic that swears by it.
Reckons thats all he/they did in europe.
I've been warned of it by a couple of workshops.
Plus, why do you need to do it, it isn't like it's stiff or anything, it's very easy to manipulate.
Oh, and the old heat wrap on the oil lines... Saves them splitting and causing fires! I have it on my return line too...
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4923255
I was told by an exhaust shop not to wrap my stainless dumps as it would make them become more brittle and prone to cracking
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4923647
Ceramic coating isnt as expensive as some people may think... Guy I work with just got a pretty long set of extractors done for less than $200 at HPC... We get trade price because of where we work but cant make that much difference... Definitely worth it too
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4923689
Its good to wrap your turbo downpipes and ex.manifold with those heat wraps.
For those who have doubts, make sure the heat wraps are soak in water for an hour
to soften the wraps. Wrap it as tight as possible to prevent future twisting and rubbing against steel surfaces/pipes.
By doing this, your pipes or welding joints wont get brittle and create cracking.
Once its soaked, wrapped and securely fasten with driveshaft ties, heat the engine up and slowly let it dry.
You will see how good it looks compared to dry wrapping. Doing it the right way will really help to cool the engine bay.
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4924417
as MrKotter said..
Wrapping will cause your mani/pipes to become brittle.
The wrap will keep the heat in and your mani/pipes will run hotter. This WILL lead to cracking if you have low quality parts and is only truly needed for race applications.
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4930627
Pretty much heard the same, not so bad on mild steel though. But with stainless it can cause it crystalise by keeping the heat in too much.
https://www.sau.com.au/forums/topic/294993-heat-wrap/#findComment-4931094
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
