PART 2
custom MR ENFORCER plenum with trumpets
xf throttle body $600
haltech e11v2 computer $1,000
eboost 2( fitted never used) $500
6 x individual coil packs OFFERS
alloy fuel rail twin -6 entries with a -8 return $100
anadised blue fuel rail twin -6 entries with a -8 return (only done 120kms)$200
seimen 870cc injectors $550
turbosmart fpr2000 fuel regulator with gauge $350
competition black 100gph carter pump
2x044 700hp pumps
twin outlet 4ltr surge tank
braided fuel lines
$650
pwr alloy radiator
1000cfm thermo fan
$500ono
jim berry custom clutch 4400pounds 4 puk solid center 50Kms on clutch r33 gear box
custom tail shaft
$2500ono
6 boost manifold
billet t72q turbo (bullet ported)
heat shield
progate 45mm waste gate
4" inlet with pod
4" dump pipe
$2,700
nos fogger system 75hp shot ( no bottle) OFFERS
vn ss diff 4.11's gear ratio $500
surge tank $50
oil filter relocation kit with braided lines $50
vl turbo rolling shell
poly bush all through car
k-mac front/rear sway bars
drilled cross sloted disc brakes
lowered king springs
sports front seats
17's vx ss rims
engineered for rb25/30
Gauges
$2,000
KIRK 0410757949 FOR ANY QUESTIONS
https://www.sau.com.au/forums/topic/295006-bighp-rb2530-sale/
PART 2
xf throttle body
$600
haltech e11v2 computer - SOLD
anadised blue fuel rail twin -6 entries with a -8 return (only done 120kms) $200
2x044 700hp pumps
braided fuel lines
SOLD PENDING PAYMENT
pwr alloy radiator
1000cfm thermo fan
$500ono
r33 gear box - SOLD
jim berry custom clutch 4400pounds 4 puk solid center 50Kms on clutch $1100
custom tail shaft TO SUIT R33 BOX IN VL - OFFERS
6 boost manifold
heat shield
4" inlet with pod
4" dump pipe
$2,700
surge tank $50
sports front seats
17's vx ss rims
Gauges
$2,000
Edited by grunter01
How much for the pro-gate on its own?? I missed out on your Tial!
Cheers
I HAVE A BLOKE THAT IS WANTING TO BUY THE HEAD/BLOCK AND BILLET TURBO SET UP, YOU WILL BE THE FIRST TO KNOW IF ANYTHING HAPPENS.
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
