skylineakt Posted December 8, 2003 Share Posted December 8, 2003 Hi Guys, I think I need a new battery for my car dude. When I go to start it sometime it will just tick once and not even crank over. And also it seem like it is strugglying to start once it starts cranking. My questions is has anyone changed their battery before for a R33 Skyline? What type/brand is good and what sort of rating is needed for a Skyline. I don't know much about car batteries beside that is starts the damn thing So any advice would be helpfull. Also how much are they usually? I have seen some that are in their $100 to some that are close to $300 bucks?! Thanks Link to comment https://www.sau.com.au/forums/topic/29501-new-battery-help/ Share on other sites More sharing options...
sewid Posted December 9, 2003 Share Posted December 9, 2003 Yes changing the battery is simple and has been covered before. Try a search. But basically you need to make sure the battery you buy as a replacement needs to be approximatly the same size as your existing one to fit in the tray and not be too tall as to intefere with speakers or such. It also needs to have quite small terminals to fit. Since it is in the boot the battery should be a sealed type, also known as maintenance free. It should not have caps that can be opened to replace water. You can pick one up from $60 and up. Link to comment https://www.sau.com.au/forums/topic/29501-new-battery-help/#findComment-603057 Share on other sites More sharing options...
blackdoggette Posted December 9, 2003 Share Posted December 9, 2003 Hi I had to buy a battery as well about two days after I got my R33. The previous owner hadn't driven it much for over 3 months. Anyway - I bought an Optima D51L - cost a FORTUNE - $315 - but that included over half an hours labour cos - and here's the important bit - the previous battery was just your STANDARD car battery, therefore unsealed and the b..... thing had spat watery acid c... EVERYWHERE and the guys at battery place had to strip EVERYTHING out and wash it all down with soapy water and bicarb... Also the old battery only had 280 cold crank amps which apparently was no good for anything.... So the moral to the story is to ALWAYS (as mentioned in a previous post) put a SEALED battery in the boot of a car. I live in Canberra and apparently here in the ACT it is illegal to have an unsealed 'normal' car battery in the boot of a car. Also make sure you get a battery with decent cold crank amps. This new one has 500 cold crank amps. AS I said in a similar post a month or so ago which I think got lost in the forum 'death' - my car almost starts without me turning the key!!!!! Hope this helps Link to comment https://www.sau.com.au/forums/topic/29501-new-battery-help/#findComment-603512 Share on other sites More sharing options...
skylineakt Posted December 9, 2003 Author Share Posted December 9, 2003 Thanks guys. Will try to search for the previous post Link to comment https://www.sau.com.au/forums/topic/29501-new-battery-help/#findComment-603527 Share on other sites More sharing options...
Redbaboon Posted December 11, 2003 Share Posted December 11, 2003 Mine came over with a crappy jap battery that only lasted about ten cranks before dying. I went and bought a Yuasa battery. Get the dude that you're buying off to check that the terminals will fit and that the footprint fits into the existing holder. Mine has a capacity of 425 CCA (I think) and it cost me around $130. Best money ever spent. Link to comment https://www.sau.com.au/forums/topic/29501-new-battery-help/#findComment-605733 Share on other sites More sharing options...
akeenan Posted December 15, 2003 Share Posted December 15, 2003 jesus, 315 for a battery... dont spend anymore then 120- 140 dollars on one. i bought a sealed battery a while ago it is meant for a truck but starts the car perfectly and i paid around 120... 300 dollars is just stupid. Link to comment https://www.sau.com.au/forums/topic/29501-new-battery-help/#findComment-607924 Share on other sites More sharing options...
skylineakt Posted December 15, 2003 Author Share Posted December 15, 2003 Yeah I went down to some battery place where they had a battery that will fit the Skyline R33 along with the right size terminals. It cost $99 bucks but I think it is only like a 380CCA. Does that matter? Like i'm not running any big ass system or anything. Just want it to start well and last long. My current battery now goes flat if the car is not started in 3 days!! Link to comment https://www.sau.com.au/forums/topic/29501-new-battery-help/#findComment-608223 Share on other sites More sharing options...
sewid Posted December 15, 2003 Share Posted December 15, 2003 should be fine. Link to comment https://www.sau.com.au/forums/topic/29501-new-battery-help/#findComment-608368 Share on other sites More sharing options...
Chucky Posted December 15, 2003 Share Posted December 15, 2003 check your ground wires before you change your battery buddy. mine use to click sometimes and not even turnover. turned out the battery wasnt charging because the ground wire in the engine bay was dirty. Car starts in 1-2seconds now with no trouble at all. Check your voltage at the alternator and then at the battery to see if theres much difference. Link to comment https://www.sau.com.au/forums/topic/29501-new-battery-help/#findComment-608444 Share on other sites More sharing options...
skylineakt Posted December 16, 2003 Author Share Posted December 16, 2003 Thanks for the tip Chucky. But I think the battery is rooted cause I have had trouble with it before and it just seem weak. Like it will even go flat if the ignition is left on for too long Link to comment https://www.sau.com.au/forums/topic/29501-new-battery-help/#findComment-608601 Share on other sites More sharing options...
Chucky Posted December 16, 2003 Share Posted December 16, 2003 how olds the battery? do you think its charging? Link to comment https://www.sau.com.au/forums/topic/29501-new-battery-help/#findComment-608695 Share on other sites More sharing options...
skylineakt Posted December 16, 2003 Author Share Posted December 16, 2003 Don't know how old the battery is as it was already there when I got the car, but i'm guessing that it came over from Japan as all it has is japanese writting and it is a Panasonic?!?! Are these the original battery the Skyline came out the factory with?! I think it is charging, after a jump start and driving around for 15-20 things are normal again. It is a weird glitch, as it only happens sometime when it will just tick and not crank. But now I have notice the car is taking longer to crank over. Link to comment https://www.sau.com.au/forums/topic/29501-new-battery-help/#findComment-609519 Share on other sites More sharing options...
craz0 Posted December 17, 2003 Share Posted December 17, 2003 The battery that was in mine had Skyline R33 written on it, I just changed mine I got a Delkor 22F610D and got the terminals and the leads changed. Have a look here...http://www.skylinesaustralia.com/forums/sh...ead.php?t=28697 Link to comment https://www.sau.com.au/forums/topic/29501-new-battery-help/#findComment-610672 Share on other sites More sharing options...
tridentt150v Posted December 19, 2003 Share Posted December 19, 2003 I converted mine to an Odyessy total seal. I can get them in the country areas. I tried and couldn't get the Yuasa battery [it was a jappa batt, even Yuasa Aust. said no go]. I had to change my leads etc, and weld up a new battery holder setup, did it all myself and ended up with a top shelf job [if you want it done right......do it yourself]. The Odyessy battery is a queer animal, nil maintenance, long life, and big crank power, they are a bit more exy though. Link to comment https://www.sau.com.au/forums/topic/29501-new-battery-help/#findComment-613186 Share on other sites More sharing options...
craz0 Posted December 19, 2003 Share Posted December 19, 2003 What is the CCA of the Odyessy tridentt150v ? Link to comment https://www.sau.com.au/forums/topic/29501-new-battery-help/#findComment-613194 Share on other sites More sharing options...
tridentt150v Posted December 20, 2003 Share Posted December 20, 2003 400a for the 800amp, and 600a for the 1000amp [i think I've got an 800, I'll check on that, but it has a few other other attributes that are supposed to make them the 'ducks guts' of batteries. Have a look on their web site [assuming they got one] or get a pamphlet. It will explain it heaps better than I can. It rapid recharges after heavy load, has a big cycle rate, can be deep cycled, long shelf life, etc etc Link to comment https://www.sau.com.au/forums/topic/29501-new-battery-help/#findComment-613728 Share on other sites More sharing options...
