I have seen pics of a twin scroll T4 flanged 1.06 A/R turbine housing that may soon be available for BB GT30 based turbos ie GT3071RGT3076R/GT3082R .
Probably not too many people wanting a big flanged GT30R but you never know . The housing looks like the one you sometimes see advertised for GR3582R's .
As usual Geoff Raicer is in the thick of anything TS but at Sema time probably hard to contact .
A .
Disco,
These are an option for the 3076 turbo's (and others) when ordering from ATP - see 3rd housing from the bottom for the 3076.
http://www.atpturbo.com/mm5/merchant.mvc?S...tegory_Code=GRT
GCG also has T3 TS housings in .82 and 1.06.
Edited by juggernaut1
I spoke to Brett @ GCG and the T3 flanged GT30 TS housings come in 0.78 and 1.06. The price quoted was a bit higher but consistent with the ones sold overseas like atpturbo.
They must have sold out of the .82 as Michael sent me pics of both the .82 and 1.06 as I was contemplating moving up from the .78. Also a member on NS recently posted up a dyno of a 3076 with .82 TS rear which he sourced from GCG.
Yup, hi name is R4Race. Link is here: http://nissansilvia.com.au/forums/index.ph...2957&st=210
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
