ok so i went to pick my car from the impound today and to my surprise the car was running. when the car was impounded before it went on the tow truck i put a 2000rpm limiter on the car through the handset removed the handset from the car unpluged the the microtech and x6 box and hid the wiring under the carpet also removed the battery isolaler switch and hid it in the boot. so my question was " how did you get the car runing" cops "we didnt touch it it came like this" at the end of the day what can i do. the cops are f**ked. but at lease they cleaned it
https://www.sau.com.au/forums/topic/295025-cops-are-fked/
Man i totally agree! I had my car go to police impound years ago. Came back without a headunit. I had removed all other items so it was the only thing that was still in there.
Thats crazy they got your car running though!!! Complimentary free police tune maybe? :laugh:
https://www.sau.com.au/forums/topic/295025-cops-are-fked/#findComment-4920210
"Cops" only do the paperwork and confiscate the car. It is towed by tow companies and stored by private contractors. They detail the stuff about he car before it gets taken away an thats the last they ever see of it. Hrdly their fault. You might want to take it up with other people.
https://www.sau.com.au/forums/topic/295025-cops-are-fked/#findComment-4923078
Except for the cars that are held in the actual police impound lots...
https://www.sau.com.au/forums/topic/295025-cops-are-fked/#findComment-4923126
I was just going off his location of Northen Beaches.
Yes country imounds are different.
yeah, NFI how Sydney impounds work...
Wollongong has 2 impounds that I know of (One for each LAC) and they're both full... So now they take them to the owners house park it on the front lawn and wheel clamp them... Public humiliation...
https://www.sau.com.au/forums/topic/295025-cops-are-fked/#findComment-4923271
The impound in which my vehicle was held in the police impound located in enfield. Its also the same place where the cops fit out their cars with sirens, radios etc. VERY police controlled but they do have civilian workers aswell. Its on the same lot as a vehicle auction place. Pickles maybe. Cant remember. I'd imagine one of the civilian workers pinched my headunit. I just find it unbelievable that it can happen in a police impound. But they are above the law.
https://www.sau.com.au/forums/topic/295025-cops-are-fked/#findComment-4924223
About as far as police control went was the managers looking after the vehicle fitouts. As stated. The towing and storage of the cars is purely private sector. Police were there from 9-5 and then it is anyones guess. It was never police property.
https://www.sau.com.au/forums/topic/295025-cops-are-fked/#findComment-4924400
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
