A what? Sounds like nonsense to me. All you need is the computer and the loom and to wire it into your existing loom via instructions off apexi. You can put it in without a tune just don't touch the settings part except to change it to a 6 cylinder (don't touch the air/fuel ratios). The rest is done when u take it in for a tune.
https://www.sau.com.au/forums/topic/295033-safc1/#findComment-4920283
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
