  • Replies 71
  • 4 weeks later...
Hi guys, I have an 2010 Infiniti FX35. I was searching on how to make my mirrors automatic and ran accross this thread.. The switch i have is the same as the R33 (open, neutral, close). I would like to try this mod out and was wondering, Tommy J, if you have any left. I would like to purchase one. I understand that its not guaranteed to work on my car and am willing to try it out.
Edited by Saleen00_227
  • 2 months later...
  • 2 months later...
I don't mean to sound rude. But don't skylines come with this anyway? I have a switch that I flick from left to right and my mirrors open up. Isn't that standard?
Hi mate, fair question. True, the switches move the mirrors in and out. But the controller basically does everything automatically. so you don't need to flick any switches. Plus you get the benefit of folding the mirrors in while the car is off. A stock skyline doesn't do this because the mirrors run off Accessory power.
I still have some if anyone is interested. $30 + P/A
-Tom
  • 10 months later...
Hi there mate,
Bit of a long shot, but do you still have anymore/able to make any more? Am dead set on getting one, I live in New Zealand but am happy to pay for shipping over here if you are able to. Thanks very much!
Dan
  • 6 months later...
Hey,
to quote exactly above ^^ any chance of getting one of these? Im in perth but have been looking for an easy solution for this "auto folding" feature for a while now.
Cheers ;)
Hi mate, no problems. $30 + $10 P&H should cover it. PM if you want one! Cheers -Tom
Hi there mate,
Dan
Hi Dan, sorry I wasn't sure if I'd responded. If you're still interested, PM your Location in NZ and I'll get you a quote for the postage. Cheers -Tom
  • 2 years later...
Hi all, still have a few left. PM if interested. Cheers
Sorry if the info is somewhere in this thread, but are they hard to install? I'd be interested in one for a s2 r33 if it makes any difference which series.
Cheers,
Chris
  • 4 weeks later...
Cheers,
Chris
Not hard to install at all. Just need side cutters, soldering iron, PVC tape etc. Instructions are pretty straight forward and easy to follow. PM if interested.
Cheers
Tom
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
