Hey Guys,
I am wondering how many Kw's I might have at my rear wheels..
Below is the list of mods:
Turbo Back exhaust (jap brand)
Apexi Panel Fiter
10-11 psi boost
AM Front mount cooler
From what I know It has a standard computer and internals..
Car has done 80 thousand km's.
I have recently purchased this car.
Any help would be appreciated.
Cheers,
Nick
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
