hi guys as it states im selling my skyline as i just bought a house and im looking to down grade with cash adjustment or just straight out sell the car. it has been very reliable and have just done a majour service on the car including gates racing timing belt water pump all oils plugs ect ect. here is the mod list for the car
mods
gcg top mount manifold
garret gt35r turbo with .82 rear housing
garret turbo benie
isc adjustable coilovers front and rear
custom one off made 3 and a 1/4 inch stanless steel ONE PIECE exhaust system sounds awsome
zenneti kaotics staggered fitment 18 by 8.5 on front and 18 by 9.5 on rear sard anodised fuel reg
550cc nismo injectors
52mm custom alloy radiator
45mm turbosmart wastegate with stainless steel screamer very loud only a week old
5 puk cushion exedy clutch
bosch 040 intank fuel pump
slotted front rotors
high flow cat
tial 50mm race port bov
drift pod with airbrushed cove and a full alloy cover so it is covered under the enginner report
drift oil catch can with braided lines
z32 air flow meter
splitfire coils
apexi power fc with hand controller
front mount cooler with custom piping cold air induction
anodised blue wheel nuts
turbosmart eboost2 electronic boost controller with led shift lights moulded into the dash
clear side indercaters
saas steering wheel
nismo shifter with short shift kit
moderfid headlights
custom plates (on gate)
custom front grill on gate
custom painted plenum and rocker covers candy blue to purple
custom cold air induction in the passenger side headlight and converted that side to h4 globe
candy front strut brace also blue to purple
air brushed dash black with white ghost flames
removed wing shaved rear boot and smothened along with the edges to give it a finish touch
leather interior black with blue stitching interior
pioneer indash 7 inch dvd player
boston acustic 6 inch speakers rear
pioneer kevlar front splits in front
pioneer 4 channel amp also airbrushed and a mono block amp, pioneer 12 inch sub in custom fiberglass box air brushed black with ghost flames all top of the line equipment
car has also got top of the range viper alarm system with a 2 way pagging remote and remote start so the key pad tells you when its being broken into and you can start the car with a touch of a button also has an inbuilt turbo timer.
i have recipts for 99% of the mods done to the car wich were all carried out in under a year.
car made 289.4rwhp on 9.8psi and 400.8rwhp at 18psi i have dyno sheet for proof car ran a 12.9 at 183klmh as the car sits no gutting street tyres ect still have slip pass
the car also has a full engineer report so is all legal car has had a full service just replaced water pump and fitted a gates racing timing belt runs great will not dissapoint
i have also just done a photo shoot with hpi magazine and should be out in the jan/feb issue
price 19800ono or trade with cash my way i need at least 5g and another car
if you have any questions just call me on 0434390208 shaun thanks guys
  • 4 weeks later...
hey guys i have now put 12 months rego on the car as of the 16 december and am now askin 19000
Edited by mrrb20det
please not guys tv has been taken out of car replaced with a pionerr ipod capable head unit and have now put brand new tyres on car
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
